> Alright, I got 3/4's of my 5 lug done.., now to do the rest.
Andyrew
post Jun 16 2003, 09:17 PM
Spooling.... Please wait
I guess I should give you guys a pic to look at.. I want to get this thing done in 2 weeks, so I think I better get crackin.. Well Hope you guys like my 5 lug!
Andrew
Replies(1 - 5)
ChrisReale
post Jun 16 2003, 09:32 PM
Sleazy
Looks great!
Andyrew
post Jun 16 2003, 09:41 PM
One other thing, (always has to have a question in here) What should I use for lug nuts? I have really long studs on the back,
(IMG:http://forums.pelicanparts.com/uploads/Long%20studs.jpg)
And the stock lugs dont reach, I have 2 lock nuts on, but thats just to hold the wheel on (although with the long studs they dont need that) so they dont dent my dads 951 track car..
(IMG:http://forums.pelicanparts.com/uploads/Long%20studs,%20fuchs.JPG)
Mueller, you said something about useing the stock nuts and just keep tightening them till the tops of them pop off. I just have bad memory, Can you refresh it for me?
Thanks guys
Andrew
Mueller
post Jun 16 2003, 11:26 PM
914 Freak!
Steel nuts or aluminum....for the aluminum ones, I've been told you can just pop the top off by screwing them on if the lug nuts are long enough and you use a deep socket (19mm)
I removed the tops off of mine with a lathe, so I guess I cheated a little (IMG:style_emoticons/default/smile.gif)
Andyrew
post Jun 17 2003, 12:08 AM
Ehh, I can use a drill (IMG:style_emoticons/default/wink.gif),
Thanks
BTW, thanks for telling me about the heat gun (hair dryer), I thought that a heat gun was something different, I have almost all of it done now, in like 2 hours. (IMG:style_emoticons/default/dance.gif)
914Timo
post Jun 17 2003, 12:46 AM
Region Association: Europe
... or you can cut the long studs. Screw first some old nut in the stud. Cut the stud and remove the nut. When you screw the nut out that will open the start of the thread. If not, you have to use small file and do it yourself.
- Lo-Fi Version Time is now: 19th April 2025 - 11:50 PM
