paintracer1 |
Newbie ![]() Group: Members Posts: 11 Joined: 2-January 12 From: Maryland Member No.: 13,957 Region Association: MidAtlantic Region ![]() |
Finally getting my 914/6 together and one question I don't think I've seen asked is what tank is best in your alls opinion. Stock/reproduction oil tank or go real cheap just use a 911 oil tank( will work fine ?)(just gonna have to figure out how to mount it?) Don't be that cheap! or get a Peterson 16 qt up front and be done with it ? More oil the better? Dropping in a 2.8 later may switch to a 3.6. Is it all about $ or How nice you want it? or size of motor and what ya going to use it for. It's going to be used 95% of the time as a weekend street car and it might see a DE a handful of times in it's life. Thanks for any insight into this decision.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Check with Eric Shea at PMB. They had a tank at Hershey that they are producing, IIRC, for sale and it is very nice. Not the most expensive thing. 911 tank wont work.
colingreene |
Senior Member ![]() ![]() ![]() Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California ![]() |
based on the questions you are asking i would say you have some more reading to do.
a 911 tank will not work in this car at all. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
911 tank wont work. a 911 tank will not work in this car at all. (IMG:style_emoticons/default/agree.gif) |
SirAndy |
Stock/reproduction oil tank or go real cheap just use a 911 oil tank( will work fine ?)(just gonna have to figure out how to mount it?) Don't be that cheap! or get a Peterson 16 qt up front and be done with it ? More oil the better? Dropping in a 2.8 later may switch to a 3.6. Is it all about $ or How nice you want it? or size of motor and what ya going to use it for. It's going to be used 95% of the time as a weekend street car and it might see a DE a handful of times in it's life. Thanks for any insight into this decision. I'm not sure if anyone still makes reproduction tanks, Patrick Motorsports maybe? I have a DW reproduction tank for my 3.6L and it works great, but he stopped making them a long time ago. I don't like the tanks up front as it puts the oil far, far away from the engine (too far IMHO). (IMG:style_emoticons/default/popcorn[1].gif) |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Eric Shea sells Ben's new reproduction tank. Ben used my oem Porsche 914-6 tank as a template to make his tank. He is an expert welder and his reproduction tanks are top notch. I am using one in my 6 conversion. The comment from our Porsche 962 mechanic was - very nice product. Yes, buy his tank. He is also making other 914 conversion products for our cars.
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Finally getting my 914/6 together and one question I don't think I've seen asked is what tank is best in your alls opinion. Stock/reproduction oil tank or go real cheap just use a 911 oil tank( will work fine ?)(just gonna have to figure out how to mount it?) Don't be that cheap! or get a Peterson 16 qt up front and be done with it ? More oil the better? Dropping in a 2.8 later may switch to a 3.6. Is it all about $ or How nice you want it? or size of motor and what ya going to use it for. It's going to be used 95% of the time as a weekend street car and it might see a DE a handful of times in it's life. Thanks for any insight into this decision. Please read up a bit more and then go the the wtb/fs section and bingo theres one on there for sale at this moment or the guy that's makes them you can contact ,don't forget the oil filler pipe,oil filter console,oil lines return and suction,tank breather hose,it mounts up to be very expensive and then you add an oil cooling system for the larger motors. You could just contact PMS and get what you need but that's $$$$ that you could spend elsewhere. (IMG:style_emoticons/default/welcome.png) sorry nearly forgot. |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Welcome to the board.. I infact build 914-6 oil tanks and Eric Shae from PMB sells them for us.. They have 22mm fittings so you can use the stock oil lines or go larger if you want.. That is the norm for reproduction tanks. I use internal baffling and .625 id plumbing just as stock factory tanks did.. Tanks are $600 oil fill necks are $135 and oil filter consoles will be done so shortly (waiting on machinest) and will be very commpetive as well..
My belief while developing them was to make a very high quality tank but yet very cost effective. If you look at the competition we are priced in such a way you will save about 400 on the package..hope this helps. ![]() ![]() ![]() |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Welcome to the board.. I infact build 914-6 oil tanks and Eric Shae from PMB sells them for us.. They have 22mm fittings so you can use the stock oil lines or go larger if you want.. That is the norm for reproduction tanks. I use internal baffling and .625 id plumbing just as stock factory tanks did.. Tanks are $600 oil fill necks are $135 and oil filter consoles will be done so shortly (waiting on machinest) and will be very commpetive as well.. My belief while developing them was to make a very high quality tank but yet very cost effective. If you look at the competition we are priced in such a way you will save about 400 on the package..hope this helps. What is the capacity of your tanks ? nice looking product |
mepstein |
Here's the guy who gave the the thumbs up on Ben's oil tank. Taking a break on the 962 to work on the V12 Mirage.
Attached image(s) ![]() |
0396 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California ![]() |
Since you have the opportunity to mingle with these exotic.
Any 993RS intake laying around ? I know, I should unload vs buy...... |
mb911 |
mb911 |
V2.0 laser cut now
porschetub |
V2.0 laser cut now ![]() ![]() Why buy PMS with quality like that ,top notch Ben ($200 cheaper than PMS),as mentioned the 911 tank is a no go ...ask me how I know,bought one real cheap with the intention of modifying it or making my own using parts off it ,just not easy,selling it to a 911 guy who can't find one so all is golden. As I have mentioned before the PMS filler doesn't work with a stock tank (dipstick length) sure Ben will have his fitting right. |
mepstein |
V2.0 laser cut now ![]() ![]() Why buy PMS with quality like that ,top notch Ben ($200 cheaper than PMS),as mentioned the 911 tank is a no go ...ask me how I know,bought one real cheap with the intention of modifying it or making my own using parts off it ,just not easy,selling it to a 911 guy who can't find one so all is golden. As I have mentioned before the PMS filler doesn't work with a stock tank (dipstick length) sure Ben will have his fitting right. I have one of Ben's old tanks and fillers. Fits and works great. New tank looks even nicer. (IMG:style_emoticons/default/smilie_pokal.gif) Ben took the measurements for his tank from my original 914-6 tank so that's probably why everything works so well. |
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
Unless you are building an original 914/6 to show I would get one of Ben's tanks.
They have more oil capacity, are more thermally conductive and are cheaper than the PMS or OEM Porsche tanks. As others have indicated a 911 tank will NOT fit in the original 914/6 location with modification. |
mb911 |
Also a note if you look at the pictures this one is built for a passenger fender. (IMG:style_emoticons/default/sad.gif) . one of my guys bent it backwards..
mepstein |
Also a note if you look at the pictures this one is built for a passenger fender. (IMG:style_emoticons/default/sad.gif) . one of my guys bent it backwards.. Aussie version? |
mb911 |
Also a note if you look at the pictures this one is built for a passenger fender. (IMG:style_emoticons/default/sad.gif) . one of my guys bent it backwards.. Aussie version? Lol yup. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:31 AM |
