Dtjaden |
Member ![]() ![]() Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California ![]() |
I am sure that many of you have been confused trying to trace electrical problems with your 914. Even for those of that are able to follow the various 914 wiring diagrams a quick cheat sheet may be helpful.On one of the Plecan boards I recently stumbled across a diagram of sorts made for 911s that greatly simplified identifying the voltage source for each fuse, their usage and value.
I have created a similar diagram for our 914s and it is attached below. Since this is a first pass some of you may identify errors and model year differences and, if so, please bring these to may attention and I will update the diagram. Also please give me any feedback as to the usefulness of the diagram. ![]() |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Very nice and useful. Thanks for making this diagram.
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Dtjaden |
It should be close. I primarily consulted the 1973 traditional wiring diagram and the 1974 current flow type diagram. Please let me know about any discrepancies you find.
North Coast Jim |
Member ![]() ![]() Group: Members Posts: 326 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region ![]() ![]() |
I am sure that many of you have been confused trying to trace electrical problems with your 914. Even for those of that are able to follow the various 914 wiring diagrams a quick cheat sheet may be helpful.On one of the Plecan boards I recently stumbled across a diagram of sorts made for 911s that greatly simplified identifying the voltage source for each fuse, their usage and value. I have created a similar diagram for our 914s and it is attached below. Since this is a first pass some of you may identify errors and model year differences and, if so, please bring these to may attention and I will update the diagram. Also please give me any feedback as to the usefulness of the diagram. ![]() Solved one of my problems that being the correct size fuse for each of the current paths. My Roller car had none installed. Haynes was no help either nor were some of the Current Flow diagrams I've obtained. Thanks. We are one step closer to electrifying the "Scarecrow" Project. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:47 AM |
