> Parking Brake
JPA914
post May 13 2016, 07:34 AM
Am I correct in assuming only the inside pads on each rear wheel are functional with the parking brake? My outer ones don't move when pulling the handle, but then again the system needs to be bled so that might be an issue. I just thought the parking brake was purely mechanical (IMG:style_emoticons/default/confused24.gif)
Replies(1 - 3)
cwpeden
post May 13 2016, 09:09 AM
Great White North, huh?
Purely mechanical, inside pad only.
JPA914
post May 13 2016, 11:09 AM
QUOTE(cwpeden @ May 13 2016, 10:09 AM) *
Thanks, that helps!
BfloRandy
post May 15 2016, 07:31 AM
Dimwit Extraordinaire
I'm certainly no expert. I was under the impression that when the parking brake arm is engaged, if the brakes are properly adjusted of course, pushing the inside pad against the rotor will also engage the outer pad because the tolerance is so small. I may be wrong...
- Lo-Fi Version Time is now: 26th December 2024 - 04:00 PM
