Help- persistent brake line fitting drip |
SKL1 |
May 16 2016, 10:28 PM
Senior Member Group: Members Posts: 1,612 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Been chasing a slow drip from the banjo fitting on top of the "proportioning valve" on the rear bulkhead.
I've replaced the 10mm and 12mm ID washers a couple times to no avail. It is a PITA working in that tight spot but the fitting is as tight as I can get it, but still has a frustrating slow drip... Any kind of gasket material (like the blue stuff) to smear on the washers to help?? Did I mention I HATE working with brake fluid???? |
Garland |
May 16 2016, 10:44 PM
Restoration Fanatic Group: Members Posts: 1,331 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
It's been said before " I wish I would have just done this"
PMB Performance - Pressure Regulator Restoration Service, The only full restoration service on the planet! PMB 914 World topic link I also think he has a kit. |
Mike Bellis |
May 16 2016, 10:55 PM
It may help to anneal the copper washers with a torch to soften them. This will help if the mating surfaces are uneven.
r_towle |
May 16 2016, 11:00 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bellis,
Start thread with loads of details of old rotary van please. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:07 AM |
