cal914 |
Member ![]() ![]() Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None ![]() |
I recently had our 1.7 serviced and they reset the gaps in the tappets but now the engine seems to make a rattle noise now,something it didn't do before hand they are experienced so i doubt that they set the wrong gaps but somethings changed
Thanks Brian |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Sounds like they don't know the right specs and got some way too loose. Ask them if they know what should be .06 vs .08 and if they know which 914s had engines that needed different specs.
Bob L. |
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region ![]() |
Does it quiet down after warming up?
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
That or they gapped chromoly rods, unwittingly. Also, check your heat exchanger for a loose fit or some tool left on top of an exchanger.
cal914 |
That or they gapped chromoly rods, unwittingly. Also, check your heat exchanger for a loose fit or some tool left on top of an exchanger. The noise is defiantly coming from the engine , when I spoke to the guy he said that the gaps where really tight could that mean that they are chromoly rods (what ever they are ) Thanks Brian |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Brian, chromoly pushrods do not expand like the stock sodium filled rods. They are adjusted at zero lash. The ends of the rods are very different from the stock, so easy to tell if they are not stock. that doesn't mean they are chromoly, just means they are not stock
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Brian, chromoly pushrods do not expand like the stock sodium filled rods. They are adjusted at zero lash. The ends of the rods are very different from the stock, so easy to tell if they are not stock. that doesn't mean they are chromoly, just means they are not stock Sodium filled push rods ???, mine are just just aluminum with open ends. |
r_towle |
Doubt the push rods were replaced, just bring it back it may just need to be done again...
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Brian, chromoly pushrods do not expand like the stock sodium filled rods. They are adjusted at zero lash. The ends of the rods are very different from the stock, so easy to tell if they are not stock. that doesn't mean they are chromoly, just means they are not stock Sodium filled push rods ???, mine are just just aluminum with open ends. Yep.... OE 2.0 exhaust valves are sodium filled. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
He said pushrods.
the pushrods are not sodium filled but the valves are. In fact they are hollow so they can pump oil to the rockers. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Check the fan
TheCabinetmaker |
Stu is correct. Sodium filled valves. Not sure what I was thinking.
Lo-Fi Version | Time is now: 26th June 2024 - 06:13 AM |
