RAX914 |
Member ![]() ![]() Group: Members Posts: 100 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None ![]() ![]() |
I haven't had a working horn on my car for some time, so after installing new fog lights, I also installed a new horn. When testing, the horn would sound continuously, when I turned the key to the on position. After removing the steering wheel, I noticed a wire wrapped around the horn contact.
![]() When I looked at the cancellation ring I figured out where that piece of metal came from. ![]() After removing the piece of metal the horn appeared to work properly when grounding the horn contact with a length of wire, so I ordered a new cancellation ring from Pelican Parts. So now I'm wondering if I should do something about the worn horn contacts, especially the upper one which has worn through. I haven't received my new cancellation ring to test the horn with the steering wheel on, but was wondering if the horn would work with mainly the lower horn contact or should I start looking for a replacement turn signal switch or is there some easier fix? |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
lack of lube = friction
Lo-Fi Version | Time is now: 26th June 2024 - 04:31 AM |
