Lost 4th and 5th now I know why |
Mikey914 |
Jul 6 2016, 11:58 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Surprise it would still even shift I guess it's time to make more new parts
Attached thumbnail(s) |
Mikey914 |
Jul 7 2016, 01:10 AM
That was pretty easy. But I did get some ideas of how to make these a little more serviceable.
Here's how I seated the bushings. Attached image(s) |
76-914 |
Jul 7 2016, 07:17 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
We had the same thing happen the day after we returned from RT66 -2013. You can also use a 1/4" long stove bolt and washer as a puller for those bushings.
worn |
Jul 7 2016, 10:50 AM
can't remember Group: Members Posts: 3,373 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
sfrenck |
Jul 7 2016, 11:22 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
I struggled with adjusting my gear shift for a couple days before I realized I had the same issue.
Mikey914 |
Jul 7 2016, 11:54 AM
yes these are a paint to deal with. I'm driving today, but there is nothing you can do (other than to limp it back in 3rd) when these go out. I have a new super sexy solution to make these easy to service. Right now they only get serviced when they fail.
Andyrew |
Jul 7 2016, 12:06 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I always wondered why those parts were not available. Every joint I had seen was in horrible condition which is why I think the custom guys cut them out and went with a different style.
Thanks Mark! |
Rob-O |
Jul 25 2016, 05:17 PM
Senior Member Group: Members Posts: 1,256 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
yes these are a paint to deal with. I'm driving today, but there is nothing you can do (other than to limp it back in 3rd) when these go out. I have a new super sexy solution to make these easy to service. Right now they only get serviced when they fail. I had vague shifting last week and then over the weekend lost 4th and 5th. Pulled the rear shift cover off and that bushing was intact (albeit loose). I pulled the bellows off the shift coupler and not only was the shift coupler bushing gone, but so was the firewall bushing! Surprised I could even get 3rd gear. So....what is this super sexy solution you speak off????? |
MartyYeoman |
Jul 25 2016, 05:40 PM
Senior Member Group: Members Posts: 1,527 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Once you get your bushings sorted, there is a longer cone point set screw that allows for safety wiring. I'm not sure if its a 911 or 912 part but it sure beats the nylon button type that's common to the 914s. Bullet proof!!
Rob-O |
Jul 25 2016, 07:02 PM
Once you get your bushings sorted, there is a longer cone point set screw that allows for safety wiring. I'm not sure if its a 911 or 912 part but it sure beats the nylon button type that's common to the 914s. Bullet proof!! Huh, mine were metal set screws (and looked pretty good). I don't think I e ever seen plastic ones. |
cwpeden |
Jul 25 2016, 07:17 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Rob-O |
Jul 25 2016, 07:31 PM
Wow, learn something new about these cars every day. I'll double check but I'm almost positive mine didn't have that. |
r_towle |
Jul 25 2016, 08:17 PM
Custom Member Group: Members Posts: 24,663 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
yes these are a paint to deal with. I'm driving today, but there is nothing you can do (other than to limp it back in 3rd) when these go out. I have a new super sexy solution to make these easy to service. Right now they only get serviced when they fail. I beg to differ. Stuff in a ton of sticks and wrap with tape or a shoe lace , done. Or, hit up the plumbing department and get some bronze bushings, again tape or shoelace. Sadly they have let go on more than one Porsche for me. |
ThunderbirdDrive |
Sep 8 2016, 01:22 PM
Newbie Group: Members Posts: 31 Joined: 3-March 16 From: Toronto Canada Member No.: 19,724 Region Association: Canada |
i thin I am likely suffering from the same issue on my '76.
Lost 4th and 5th recently. Tried adjusting the shift linkage in case the left to right calibration was off, but I noticed tons of free play between the rear linkage bar and my shift lever in the cockpit. Is the coupling on the rear side of the firewall or inside the car under my center armrest? Can I inspect the coupling without removing the entire linkage? Is there a trick to removing the rubber boot at the rear of the firewall? I didn't notice any clamps and I was afraid to make a tear by pulling on it too hard. Thanks!! |
ChrisFoley |
Sep 8 2016, 01:59 PM
I am Tangerine Racing Group: Members Posts: 7,968 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Is the coupling on the rear side of the firewall or inside the car under my center armrest? Can I inspect the coupling without removing the entire linkage? Thanks!! The coupling is on the rear side of the firewall. It can be inspected by moving the rubber boot which is only held onto the firewall by friction. |
jim_hoyland |
Sep 8 2016, 02:01 PM
Get that VIN ? Group: Members Posts: 9,561 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
QUOTE So....what is this super sexy solution you speak off????? (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) This will be great ! When Will they be available ? (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) |
BigFour1973 |
Sep 8 2016, 03:13 PM
Member Group: Members Posts: 187 Joined: 16-November 14 From: Long Beach Member No.: 18,126 Region Association: Southern California |
Had this happen to me when I pulled the car from storage. I was driving around and went to down shift from 5 to 4 and when I went for 4 it hesitated a bit and i knew something was off. Slowly let the clutch out and rpms started to creep up. Almost down shifted from 5th to 2nd at 45-50 mph.
ThunderbirdDrive |
Sep 9 2016, 08:21 PM
Rand |
Sep 9 2016, 08:29 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I beg to differ. Stuff in a ton of sticks and wrap with tape or a shoe lace , done. Or, hit up the plumbing department and get some bronze bushings, again tape or shoelace. Sadly they have let go on more than one Porsche for me. What was that smiley you threw at me a while back? (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 12:18 PM |
