scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
well i fixed the wiring, even upgraded some wiring while in there like added fuses where there when NONE on wires that connect to the battery directly. added a few grounds because when it melted down one of the things that took the most damage was the ground wires.
then i took here for a drive out on the highway about a 40 min drive, it got hot but not hot enough to over heat. at this point the scoop is not even attached to the bottom of the radiator, there is about a 1.5 inch gap. i did this as a test as a worse case, i know once i seal it up it will be better. also it does not cool fast enough for me at lights with one fan so today i am going to install another. |
VegasRacer |
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,526 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None ![]() ![]() ![]() |
Great news Scott. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
I would hate for you to miss the WCC. See ya in about 9.14 days. (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) |
scotty914 |
well tonight i added a second fan controled be the heater lever, and it will be controlled by the brain as well. i installed the over flow tank as well. so it should run cooler, i will take it out again tommarrow to see how the temp does
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) After the lambasting I received the other night, I am reluctant to say anything but I will. Congratulations! Glad you got it werked out, and dare I ask what the original problem was?? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Will I live to see tomorrow? Time will only tell. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
scotty914 |
sorry scott, i was in a slightly bad mood at the time. and you just happened to make a joke at the wrong time, i am sorry again
the problem was i think the head light switch shorted and there is a wire that goes to the head light switch that is unfused, so when it shorted there was nothing to protect it from melting down and into other wires. |
scotty b |
Well again, glad it is fixed, and hopefully I will get to see it by the end of the year. Looking forward to Pa.! Oh and I'm just bustin ya about the "mood" (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 06:29 AM |
