Cabinet identified the TTS sensor and the holes, ty, Know what it does now |
oakdalecurtis |
Aug 27 2016, 08:34 PM
Oakdalecurtis Group: Members Posts: 1,346 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
After I got the throttle body off on my '76 2.0, a couple of questions. There is a sensor under the throttle cable, white wire was broken off, I repaired the wire, what does the sensor do?
Also, under the throttle cable in the tin on the passenger side is a clean 1/2 inch hole, what is it there for, looks like it was taped over at some point? Finally, there is a machined approximately 1 inch hole in the back of the engine bay wall about car centerline, in the circle in the picture with the blue glue residue around it, and the remains of a small black plastic cap were underneath it. What is the hole there for and should it be covered? Anyone on any of this stuff? |
TheCabinetmaker |
Aug 28 2016, 10:36 AM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
First pic is the thermo time switch. The hole in the tin is for a push in plug wire holder. They are available new. Bug/bus part. The hole in the rear tin had a plug with a strap for the wiring harness. Iirc
oakdalecurtis |
Aug 28 2016, 11:17 AM
First pic is the thermo time switch. The hole in the tin is for a push in plug wire holder. They are available new. Bug/bus part. The hole in the rear tin had a plug with a strap for the wiring harness. Iirc Thank you Cabinet, sounds like I don't need to be concerned about either hole, or the TTS sensor here on the west coast, even though I did hook it back up. |
Gunn1 |
Aug 28 2016, 11:19 AM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
First pic is the thermo time switch. The hole in the tin is for a push in plug wire holder. They are available new. Bug/bus part. The hole in the rear tin had a plug with a strap for the wiring harness. Iirc Thanks for Identifying the thermo switch, wasn't sure what it was either. (IMG:style_emoticons/default/beerchug.gif) |
ConeDodger |
Aug 28 2016, 12:01 PM
Apex killer! Group: Members Posts: 23,852 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
If it works, the TTS is a good thing. If it doesn't, it's a vacuum leak and a high idle problem. Very few of them close in my experience. I think I've tried a half dozen...
TheCabinetmaker |
Aug 28 2016, 01:10 PM
Huh? Tts has no vacuum. Just a wire. I think you mean aar.
Lo-Fi Version | Time is now: 26th December 2024 - 04:35 AM |
