echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
Sorted through the fuel pump issues that I was having with the boards help.
Went through the vacuum hoses for the FI system and it all appears to be correct. car is a stock 72 1.7 D-jet NOW: The car turn over fires then revs high to 3000 for a couple of seconds then dies. I remember this happening to my 74 right after it needed a top end rebuild for failure of which I cant recall How should I go about checking to see if the engine has had a failure Compression test? anthing else? Other open ended possibilities that run through my mind are MPS problems, incorrect fuel pressure cuz I still havent been able to find a guage/tester that I can run with inline with this setup. |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
how does it die....just cut out and die (liek turning the key to off) or does it stumble and sputter
echocanyons |
It seems to start then rev high then tapers off then cuts off. The throttle does seem to have any effect on what the engine does either.
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Maybe your fuel pressure is too low. Does you pump run. Why not jut go get a cheap 0-50 lb gauge and tap into the feed side and see what pressure it's got?
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Pressure or filter....
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
does the fuel pump run when the starter is engaged? Sounds like you are getting enough fuel to start when the key is first turned on, and the pump first runs. Make sure it continues to run when the starter cranks.
bd1308 |
ayup. agreed
echocanyons |
So I tested the PSI at the D side of the fuel pump =52 PSI
The reference I have says it should be 28.5-30.8 but I think this is after the pressure regulator. I am going to attempt to tap into the regulator and meaure that |
Allan |
Mine was really high because the pressure regulator was in backwards. I don't know if the 1.7 has a cold start valve but you might also want to check down into the plenumn and take a look for a lake of fuel. Mine was forcing fuel through the valve and just dumping it in. I'm glad it didn't fire. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Oh yeah, injectors don't like high pressure. |
echocanyons |
Across the regulator I measured 30-51 PSI
52 while cranking and 30 at rest. Should I adjust the regulator so the peak is 30? How do I tell if it is on backwards? |
Joe Bob |
That's NOT bad....have you pulled a plug to see if they are wet? Are you sure you are getting spark? The injectors are pulsing?
echocanyons |
I pulled one injector and the spray looked good.
I havent pulled a plug, I guess that is my next step |
Allan |
Is is basically a one way flow valve. Pull the line on the side currently going to the return and see if anything comes out. I don't think you want anymore than about 30 lbs. of pressure. See if you can reduce the cranking pressure down to that and see if it is stable. |
TheCabinetmaker |
52 while cranking is too high. There is something wrong. Maybe a kinked return hose, or like Allan said, the regulator is in backwards. The adjustable side of the regulator is the "out"side.
echocanyons |
This was not testing inline but rather at the line so in essence the return line was kinked with the pressure guage.
I will have to rig the tested with a tee so I can test inline. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:43 AM |
