> wipers landing on drivers side, took apart my dash
jrblackbox
post Oct 20 2016, 03:11 PM
After putting my early dash back together,the wipers are landing on the drivers side of the windshield. Is a wire crossed or somehow the switch is in wrong? TIA
Replies(1 - 18)
Mike Bellis
post Oct 20 2016, 03:12 PM
Resident Electrician
Mine land on the drivers side.
post Oct 20 2016, 03:37 PM
Resident German
QUOTE(jrblackbox @ Oct 20 2016, 02:11 PM) *
That's how they are supposed to be, looks like you fixed them!
jrblackbox
post Oct 20 2016, 03:53 PM
oh boy! I would prefer that they land on the passenger side! Anyway to make them land on the opposite side?
fixer34
post Oct 20 2016, 04:51 PM
QUOTE(jrblackbox @ Oct 20 2016, 04:53 PM) *
Funny you should ask. Like this? (mine is the green one in the center)
post Oct 20 2016, 04:55 PM
Yes. It's posted here somewhere but I'm terrible with searching.
fixer34
post Oct 20 2016, 05:20 PM
I did mine a number of years ago. I think I found a link on Dennis Deed's Yahoo Group board that referenced yet another board/site.
Just looked to see if I kept notes/emails about it, but can't find anything.
I'm thinking it was fairly 'simple'; park the wipers as normal, disconnect the motor cable. Loosen the drive arm on the motor and rotate it 180 degrees. (I think you have to pull the assembly to do this, which also means pulling the gas tank...). When reinstalling the wiper arms, they go the passenger side. Leave them loose 'just in case' and try the wipers. They should sweep normally, but then park on the passenger side.
The wiper arms are bent, so they don't lay nicely along the base of the windshield; I never bothered trying to find another set or re-bend mine.
Dave_Darling
post Oct 20 2016, 05:41 PM
914 Idiot
Here's a how-to guide: http://www.pelicanparts.com/techarticles/9...er_reversal.htm
Yes, it's for 911s. Works for 914s as well.
--DD
post Oct 20 2016, 06:34 PM
914-6 GT in waiting
Porsche's are suppposed to park on the driver side.
yellow75
post Oct 20 2016, 06:45 PM
I never drive in the rain so it seems like a lot of BS for something so cometic..
johnhora
post Oct 20 2016, 07:22 PM
Early 911 65/66 park on pass side
the problem I found was the driver side wiper did not clean as much of the windshield as later 911/914 with the parking on driver side.
fixer34
post Oct 20 2016, 07:51 PM
QUOTE(Dave_Darling @ Oct 20 2016, 06:41 PM) *
--DD
I think that is the one I used. Although Pelican's ad hawking wiper blades that cut off part of the pictures and wording irritated the hell out of me. I didn't see any way to close/get rid of the ad.
wndsnd
post Oct 20 2016, 08:07 PM
You wanted a horse, but got a goat. Nobody wants a goat....
Check my COTM..
Elliot Cannon
post Oct 20 2016, 10:32 PM
Group: Retired Members
I prefer mine on the passenger side. To get them to stow properly I bent the arm of one side. Not sure which. I probably doesn't totally cover the drivers side of the window but it doesn't really rain that much here anyway. (IMG:style_emoticons/default/biggrin.gif)
Mark Henry
post Oct 20 2016, 10:39 PM
that's what I do!
Not much to the actual job, getting to it is the beotch, you have to remove the airbox. (IMG:style_emoticons/default/huh.gif)
7TPorsh
post Oct 21 2016, 10:41 AM
7T Porsh
Parks on the driver's side because when you need the wipers fast so the driver's side gets cleaned first. Wipes the water over to the passenger side.
If vice versa not good. Ever been driving and a car or bus next to you or on the other side of the road kicks up a surge of water on you? and you panic cause you can't see?
sixnotfour
post Oct 21 2016, 12:10 PM
I can park mine left, right, or straight up... (IMG:style_emoticons/default/blink.gif)
Elliot Cannon
post Oct 21 2016, 12:26 PM
QUOTE(7TPorsh @ Oct 21 2016, 09:41 AM) *
Panic? Panic? I never panic. I have been known to emit a high frequency scream on occasion but panic? Never. (IMG:style_emoticons/default/av-943.gif)
Root_Werks
post Oct 21 2016, 12:36 PM
Village Idiot
Most 914's I've seen don't have the arms installed correctly. If installed correctly, they are hard to see, even from the Drivers position. The attached picture is sort of hard to see: The pass-side arm should have the bend and be parked almost touching the window trim. The drivers-side arm should be straight and parked having the low end of the wiper blade almost touching the window trim.
Most arms I've seen either have two pass-side arms or arms reversed etc. You can easily park factory arms in the factory position and pretty much out of sight when not in use.
- Lo-Fi Version Time is now: 4th January 2025 - 08:35 PM
