kaiserms |
MSKaiser ![]() Group: Members Posts: 26 Joined: 8-September 16 From: waterford, michigan Member No.: 20,378 Region Association: Upper MidWest ![]() |
[size=6]
I removed the rear swing axles from my '73 914 to replace the bushings & wheel bearing and have powder coated. I have torched out 95% of the old rubber bushings but still can't budge the axle that goes through the center of the control arm. Do I need a stronger torch? Been using small cannister camp stove for torch fuel. Need some clear advice, Thanks, Kaiser |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
[size=6] I removed the rear swing axles from my '73 914 to replace the bushings & wheel bearing and have powder coated. I have torched out 95% of the old rubber bushings but still can't budge the axle that goes through the center of the control arm. Do I need a stronger torch? Been using small cannister camp stove for torch fuel. Need some clear advice, Thanks, Kaiser Use a shop press of a cheap gear puller from Harbor Freight. Clamp it on the flange. I knocked out 5 of them tonight. Replaced the threaded rod with one about 14" and just drive the pivot shaft out. Added a VW bus nut nut threaded onto the pivot shaft to keep the threaded rod centered on the pivot shaft. It does help to heat the metal until the rubber starts to smoke. If the shaft is badly rusted on the ends it is hard to push them through the rubber bushing. Push it one way a little and it if is bulged with rust grind it down and push it back the other way. Attached thumbnail(s) ![]() ![]() ![]() |
kaiserms |
BD,
I keep trying to say thanks. Can't get this message system wired. Question: Did you double nut the 14" shaft onto the existing threads of the bolt in the control arm? Kaiser |
bdstone914 |
I put a open end lug nut on the pivot shaft to kep the driving threaded shaft from drifting off. Also use grease on the end of the rod and on the threads of the shaft.
bdstone914 |
I just saw you are from Waterford MI. That is where i grew up. Not nany 914s left around there.
So we are like 914 brothers. LOL |
kaiserms |
It is Bruce, right? Ok, guess that makes sense now. Thought that's what you did. Now i can just source out the gear puller or line up a press. Thanks. So, we swapped states. I was born in L.A. & raised in Anaheim. Never cared much for Southern Cal. My best times were spent with Porsche Owners Club. They were the real racing club. Ran Willow Springs, Laguna and Riverside many times. Ironically, race tracks are now much closer. I have trusty old Waterford Hill and the brand new M-1 Concours track in Pontiac on Woodward, both within 5 min of my house in Waterford. You're right about 914's. When I went to the PCA day to observe the PCA guys said they had not seen a 914 out at the track for years. Guess I'll just have to go show these GT-3 guys how to drive! Take Care Kaiser |
Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,199 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
If you burn out enough of the bushing the shaft will essentially fall out. It takes a lot to burn them out. I used a propane torch and just propped it up so it kept heat on the bushings. As it started disintegrating I would move away the burnt bits with a screwdriver. Press would have been quicker but it eventually got the job done.
Make sure that they do not powdercoat the area where the new bushings insert. It is a very tight fit as is. |
kaiserms |
If you burn out enough of the bushing the shaft will essentially fall out. It takes a lot to burn them out. I used a propane torch and just propped it up so it kept heat on the bushings. As it started disintegrating I would move away the burnt bits with a screwdriver. Press would have been quicker but it eventually got the job done. Make sure that they do not powdercoat the area where the new bushings insert. It is a very tight fit as is. Thank you Amphicar, I thought I could step up the amps from my camp burner. I have access to a gear puller so I may still resort to that. Also, thanks for the reminder on the powder coating. I was concerned about that too. I have an old race buddy that has an Amphicar. Those have got to be going up in value by now? Kaiser |
Lo-Fi Version | Time is now: 26th June 2024 - 06:10 AM |
