rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
I just picked up a late 2.0 l engine and need to plug the air port in the heads. What do I need? I'm not going to be pumping, i just want the blocked
A search shows just threaded a 10x1.0x50 bolt into it Best -Robert |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,731 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Call Engine Builders Supply in Reno. They have threaded plugs. Same size as 911
DavidSweden |
Member ![]() ![]() Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia ![]() |
I just picked up a late 2.0 l engine and need to plug the air port in the heads. What do I need? I'm not going to be pumping, i just want the blocked A search shows just threaded a 10x1.0x50 bolt into it Best -Robert If you mean the holes for the smog injection, I used 1/8" NPT plugs. They worked fine for me |
Lo-Fi Version | Time is now: 18th June 2024 - 07:16 AM |
