Wap, wap, wap. |
Wap, wap, wap. |
Bee Jay |
Apr 25 2005, 04:54 PM
Member Group: Members Posts: 204 Joined: 22-April 05 From: Lompoc, Ca. Member No.: 3,964 |
I didn't make the WCC because of this sound coming from the engine compartment. It didn't get louder when we plugged the tailpipe. I ran a compression check this weekend. Cylinders 1,2 & 3 were 100lbs +- 5%, but number four was only 50lbs. OK, the head is either cracked or the head to piston seal is gone. There are only 4K miles on the engine since Wayne Dempsey, Tom Gould and I built it in 2000. There was a lot of debate at the time on whether or not to include the copper "head gasket" and the popular advice was to leave it out. Am I to regret that decision? My 3.0 motor isn't ready, I haven't even started tearing it down yet, so I guess I need to drop this 2.0 liter, and repair the head leak, if I want to drive it this summer.
Bee Jay My car: http://www.picturetrail.com/gallery/view?p...2754&uid=598455 |
Allan |
Apr 25 2005, 04:58 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I remember hearing it at Crusty's place. Everybody seemed to have a different opinion as to what it sounded like. I never said anything but it does sound like a head leak. I left the head gaskets out of mine and so far so good.
Oh by the way, way bitchin car!!! |
r_towle |
Apr 25 2005, 05:15 PM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
if its head to cylinder, then you need to make sure those surfaces are lapped correctly prior to final assembly...otherwise it will happen again.
the machining is very important that the cylinder to head and cylinder to case connections. These must be square and flat...then lapped. Good luck No gaskets if done correctly. Rich |
Cap'n Krusty |
Apr 25 2005, 05:33 PM
If your machinist does the job right, why would you want to introduce the random uneveness of lapping the heads? He uses years of experience, and a real expensive and real precise vertical milling machine. Costs and weighs more than your car. You use your hands, tools not known for their precision, nor the repeatability of the results. As for leaving out the head gaskets on an engine designed to use them, I fail to see the benefits. Porsche decided to leave them out of the 964 motors, BY DESIGN, and it has been a nightmare for both them and the car owners. VW took them out of their 2 litre heads, but they also lowered the compression, redesigned the heads, and added an EGR system in an attempt to keep the combustion temps down. Didn't work, BTW. The Cap'n
Dave_Darling |
Apr 25 2005, 08:09 PM
914 Idiot Group: Members Posts: 15,067 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
VW also told their mechanics to leave them out of every Type IV engine that came in and had the heads off...
--DD |
ArtechnikA |
Apr 25 2005, 08:21 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
yes they did; i've seen the service bulletin. it also says to use a shim of comparable thickness under the cylinder to restore the deck height... |
Bee Jay |
Apr 28 2005, 03:26 PM
Well, I tried without gaskets and look what happened. So I think I'll give gaskets a try. Cracked head or bent valve is a possibility also. I won't have time to drop the engine for a couple of weeks.
Bee Jay |
Cap'n Krusty |
Apr 28 2005, 04:46 PM
Not in the manual, and I haven't seen a TSB to that effect. Might be one, mind you, but I've never seen it, and the guys who do my headwork never heard of it either .................... The Cap'n |
davep |
Apr 29 2005, 11:30 AM
914 Historian Group: Benefactors Posts: 5,225 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Could someone post the SB please.
MarkV |
Apr 29 2005, 02:33 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
ArtechnikA |
Apr 29 2005, 02:58 PM
okay - *this* time i have it bookmarked so i have a chance of finding it the next time the question comes up.
this is also the "oil squirter connecting rod mod" TSB... |
Bee Jay |
Jul 18 2005, 10:52 PM
I got the head off. Here is a pic of the head. Surprise, I did put the gaskets in. The one on the right failed. Now I have a burn hole in the head. I hope it can be repaired with welding. I guess I will try without gaskets next.
Bee Jay http://www.picturetrail.com/gallery/view?p...2754&uid=598455 |
redshift |
Jul 18 2005, 10:58 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Sorry man... NICE CAR!
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Damnit. Miles |
echocanyons |
Jul 18 2005, 11:04 PM
Advanced Member Group: Benefactors Posts: 2,098 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
So since you have the heads off was there piston clearance issues?
The valves look pretty clean |
scotty914 |
suby torque rules Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
suburize it
Joe Ricard |
Jul 18 2005, 11:49 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
So I was playing with this stuff called "alumalloy" (sp)
Anyway it is a method of technically speaking soldering aluminum. It is not welding but once the stuff is heated and bonded you can't re-melt it with the propane torch used to get liquid the 1st time. Some sort of Mechanical process to make the Alumalloy rod once it is heated the two parts alloy and are pretty tough. Generally accepted method is welding. But you better find somebody that welds aluminum everyday. Get the head too hot and you will have a pile of junk. |
Dead Air |
Jul 19 2005, 12:05 AM
Senior Member Group: Members Posts: 1,268 Joined: 9-May 04 From: Buffalo, NY Member No.: 2,042 |
Great car!! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
We can't seem to let this head gasket thing go, can we? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
rhodyguy |
Jul 19 2005, 07:40 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,198 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
mr b.e. jones i take it? i still have your card.
k |
aircooledboy |
Jul 19 2005, 08:36 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
As the Cap'n has pointed out over and over, that SB does not appear to apply to our engines (unless you are running a bus engine that was remanufactured and modified after May 31, 1990). (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
tat2dphreak |
Jul 19 2005, 09:25 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
man, that car is way cool man! I dig the little touches, like the S2000 button... cool! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Lo-Fi Version | Time is now: 4th January 2025 - 06:16 PM |
