Need Help To Convert 911 Stock Muffler For 914-6, I'm Sure Somebody Has Done This? Template? Suggestions? |
Lucky9146 |
Dec 3 2016, 08:52 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,623 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Have a '74 doing 914-6 conversion running headers. It is an original Porsche muffler 2 in one out 911 muffler. Don't really want to go sport muffler. Engine is not yet installed so can't mock up. As I understand it it is a matter of clocking the outlet. I need to know if just clocking is true or how much the outlet needs to be modified or different outlet? Like to get this done now so it is ready for when engine does go in? Have the time to work on small projects but not on the car right now with other priorities and accessibility. Wondering if there is a template or documentation or something to do this? Appreciate any help. Thanks!
Steve |
Dec 3 2016, 10:51 PM
914 Guru Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
It's easier to just leave the rear valance off and figure it out after putting the drive train in.
PancakePorsche |
Dec 4 2016, 03:48 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
The amount of work depends on which 911 muffler you have, they have a couple different outlet orientation. That being said, the muffler tip exits the same location as a 2 liter /4 car so use that valance as a guide. Correct -6 muffler has a 911 part number but is unique only to the 914-6. It will be easier to do mod after installed in car, or sell the family cat to help fund a Dansk 914-6 replacement.
Cairo94507 |
Dec 4 2016, 09:03 AM
Michael Group: Members Posts: 9,843 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Much easier to orient the outlet with the engine in the car. The hold the valance up to the car and you will see what you will need to do with the tip to get it to fit correctly. If memory serves me the tip is angled down and outward slightly.
forrestkhaag |
Dec 4 2016, 11:35 AM
I am at the same point somewhat... I have the headers and the 3.0-6 not yet installed. My plan was (is) to install the motor and tranny, then the headers / and then my recently purchased SS Dansk that mates to my 2.0 valence perfectly with my current bracket on my 2.2 four.
Then, while on the rack, I will fabricate the joining two pipes that mate to the headers and to the Danks muffler. My question is more complicated. What is the difference in the innards of a 2.0 Dansk and a 914-6 Dansk innards? If there is little or no difference, i will save hundreds of dollars simply doing the fab-work on the joining pipes. Has anyone done a reuse for a six of a dansk two in one out (for a 3.0) and, if so, can you comment on the sound quality verses biting the 700 dollar bullet. |
mb911 |
Dec 4 2016, 12:04 PM
914 Guru Group: Members Posts: 6,925 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am at the same point somewhat... I have the headers and the 3.0-6 not yet installed. My plan was (is) to install the motor and tranny, then the headers / and then my recently purchased SS Dansk that mates to my 2.0 valence perfectly with my current bracket on my 2.2 four. Then, while on the rack, I will fabricate the joining two pipes that mate to the headers and to the Danks muffler. My question is more complicated. What is the difference in the innards of a 2.0 Dansk and a 914-6 Dansk innards? If there is little or no difference, i will save hundreds of dollars simply doing the fab-work on the joining pipes. Has anyone done a reuse for a six of a dansk two in one out (for a 3.0) and, if so, can you comment on the sound quality verses biting the 700 dollar bullet. Are you talking 4cyl muffler to 6 cyl muffler? It would work fine. I did it the other way for a client years ago using 6 muffler to convert to 4cyl for a 912e.. |
porschetub |
Dec 4 2016, 12:08 PM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Much easier to orient the outlet with the engine in the car. The hold the valance up to the car and you will see what you will need to do with the tip to get it to fit correctly. If memory serves me the tip is angled down and outward slightly. (IMG:style_emoticons/default/agree.gif) ,only way really,PO supplied muffler had a large exit pipe tack welded on when I got it,wasn't to fussed with the clearance so I cut one weld and moved it. Its a large pipe but I liked the look better than the puny sized stock one,it produces more noise for sure . I think there is a guide somewhere (Pelican forum?) to convert a one in one out later muffler to two one out,these mufflers can be bought used for way less $$,I did think of it as I have one that is in much better condition than the dented one I'am using now. IMO the stock muffler is a well made and a cheap alternative to expensive aftermarket ones that offer a little more power,the downside is the weight however. |
forrestkhaag |
Dec 4 2016, 12:09 PM
I sure hop mb911 is correct as this 4 to 6 reuse is my goal to save about 800 bucks.... (IMG:style_emoticons/default/piratenanner.gif)
(IMG:style_emoticons/default/beerchug.gif) |
mb911 |
Dec 4 2016, 12:39 PM
I sure hop mb911 is correct as this 4 to 6 reuse is my goal to save about 800 bucks.... (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/beerchug.gif) Look m&k exhaust.com I was the original owner and designer.. So got a little bit of street cred lol |
Lo-Fi Version | Time is now: 20th June 2024 - 06:27 AM |
