Wayne |
SoCal-Bumblebee ![]() Group: Members Posts: 47 Joined: 29-January 16 From: Orange County, CA Member No.: 19,612 Region Association: Southern California ![]() |
![]() Hoping someone out there can help me out. I finally found an OE LE Spoiler but it didn't come with the 2- Mounting brackets Thanks everyone |
87m491 |
Member ![]() ![]() Group: Members Posts: 276 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States ![]() ![]() |
Easy enough to fab, not much to them, other than the creases are at slightly odd angles.
Hoping someone out there can help me out. I finally found an OE LE Spoiler but it didn't come with the 2- Mounting brackets Thanks everyone (IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1485381201.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1485381201.2.jpg) |
Wayne |
[quote name='87m491' date='Jan 25 2017, 04:53 PM' post='2448003']
Easy enough to fab, not much to them, other than the creases are at slightly odd angles. Yes that's the plan if I cant find someone with these laying around |
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
My aftermarket, fiberglass LE spoiler mounts right to the bumper and the body. Is that no the correct way to mount it?
Wayne |
![]() Thanks , Wayne |
Mike Fitton |
Senior Member ![]() ![]() ![]() Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest ![]() ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,921 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Real LE spoiler brackets are NLA.
87m491 |
Pretty damn sure an "original" mounts right to the bumper and body as well...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1485525250.1.jpg) My aftermarket, fiberglass LE spoiler mounts right to the bumper and the body. Is that no the correct way to mount it? There is a reason why yours is an aftermarket one. |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,190 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
I think the brkt itself isnt to complex but the hardware is specific.
You might note on the OE spoiler the hole The "bolt" passes through is square. The slotted end is the spoiler side & the slot dimension allows the sqr shoulder some fore/aft location. The carriage bolt fastener shoulder is square to fit through both. something like this: Attached image(s) ![]() |
914werke |
Pretty damn sure an "original" mounts right to the bumper and body as well... (IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1485525250.1.jpg) It doesn't mount to the bumper at all. |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Attached thumbnail(s) ![]() Attached File(s) ![]() |
Wayne |
Hey Jeff those 2- in your Pic will work just fine (IMG:style_emoticons/default/piratenanner.gif) I'll take um (IMG:style_emoticons/default/sunglasses.gif)
87m491 |
Fair enough, I meant, and I suspect the OP on the topic meant his mounted to bulkhead (and fender) behind the bumper. My overall point of he has a replica LE, chances are it mounts exactly like the OE piece did.
[/quote] It doesn't mount to the bumper at all. [/quote] |
87m491 |
I'll jump into the breach again. I believe pick posted above shows the slotted end mounting to the under body, which seems appropriate as the shorter length from the kink doesn't look long enough for it to clear the bracket cover. Also the suspension side bolt is like twice the size of the spoiler bolt bolt and I'm guessing it wouldn't go through the smaller hole.
(IMG:http://www.914world.com/bbs2/uploads/post-19612-1485451352.jpg) I think the brkt itself isnt to complex but the hardware is specific. You might note on the OE spoiler the hole The "bolt" passes through is square. The slotted end is the spoiler side & the slot dimension allows the sqr shoulder some fore/aft location. The carriage bolt fastener shoulder is square to fit through both. something like this: |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
914werke |
I'll jump into the breach again. I believe pick posted above shows the slotted end mounting to the under body, which seems appropriate as the shorter length from the kink doesn't look long enough for it to clear the bracket cover. Also the suspension side bolt is like twice the size of the spoiler bolt bolt and I'm guessing it wouldn't go through the smaller hole. You may be correct. Its been some time since I installed mine and I just remember carriage bolt fitment thru the spoiler (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:54 AM |
