cwpeden |
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada ![]() |
I have an old seat that was rotten through the upholstery and thought about glassing some side supports and loops for the lap belt and shoulder straps.
I figured I would first add a steel frame like 3/8 round bar or 1/2in heavy wall tubing then glass over top of that. Has anyone done that? And what would inspectors think and a DE or Autocross? Maybe a pic or 2? |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Trekkor did this years ago. Here's a trip through time, sponsored by Home Depot. (IMG:style_emoticons/default/biggrin.gif)
http://www.914world.com/bbs2/index.php?sho...228 |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,342 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
Cut sheet aluminum to the bolster shape and rivet in. Then foam over. Added advantage is that it can be tweaked to accommodate 'wider' sitters.
It how it's done at that engine swap place. |
cwpeden |
Hmm, I searched for bolster and came up empty.
I guess it isn't too much of an issue if the original unchanged seat is under there. I couldn't find anything in PCA Parade regs or SCCA solo regs other than size. Right on, here we go then. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:23 PM |
