yarin |
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States ![]() |
There is a 1/2 demolished connector on the tranny going nowhere. I need backup lights on this car.
Does this 2 pin connector run to the 4 pin connector on the relay board in the engine compartment? If not where does it go? I've got one empty connection on the relay board. Its the T one on the rear left corner of the car. Does anyone have what I need? Thanks |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
i suppose your car has carbs? the connector you describe is for the FI brain connection ... the 2 wires from the tranny go into the harness and then through the large connector on the back of the relay board. usually, there's nothing wrong with the circuit or wires, it's usually the connector in the tranny that brakes. they're fairly cheap and easy to replace ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
yarin |
Yes i have carbs.
Sounds good to me. I'll try to find the wires coming out of the connector. Thanks |
SirAndy |
to test the circuit, simply take the 2 wire ends that go into the backup switch and connect the two. your backup lights should come on. you might have to turn on the key, i'm not sure about that tho, easy test before you dig into it too deep ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Yes you have to turn on the key.
Lo-Fi Version | Time is now: 26th June 2024 - 04:25 AM |
