bmcwilli |
Member ![]() ![]() Group: Members Posts: 133 Joined: 28-April 05 From: Chapel Hill NC Member No.: 3,998 ![]() |
My 74 2.0 has a complete, original, (of course it's not factory..even I know that (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) )
The compressor turns on, the interior fan works, the condesor fan runs. It's all there, and I suspect it could be made to run with seals, hoses etc. I am trying to decide if I should keep the AC in the car or not. I am moving slowly upt he performance/handling ladder, to start with shocks, sway bar, billet hubs, 911 disks etc. I want to auto-x some, having attended alocal novice day and gotten bit by the bug. My dream is to one day install power by Jake. I can live without the AC, and I hate the big hole in the front trunk where the condensor is installed. Course if I remove it, I gotta cover that hole.... I live in NC, yes it gets hot, but this is not a daily driver. Just looking for opinions. What would you do? And..does anybody want to buy an AC? |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
I will be installing heat and AC in my Chalon but it is not a daily driver, more of a street cruiser that moves pretty good. On a 4 cylinder car, I would think the loss of power would be a major drawback. I have never driven one with air so I dont know for sure. I do know, compressors put a lot of strain on the engine in most cars. The other drawback is retrofitting it to the new freon. The old stuff is too expensive and hard to get. I would remove it and fill the holes.
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
What do you want for it?
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
There's your answer....................damn tejasans. |
bmcwilli |
Clay,
I PM'd you. Thanks |
mharrison |
Why do I bother???? ![]() ![]() ![]() Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 ![]() |
I got involved in this same debate recently. The consensus seems to be that if you replace the compressor with a new rotary style compressor that the drag is very minimal. (Although that was a point of contention on the posts, the people who were actually running A/C seemed to indicate that it was minimal.)
sanden compressors were mentioned. It seems to me that alot depends on your climate and usage. If building an autocross car that you'll drive sometimes, then I'd say no. If you're building a driver that you'll autocross sometimes, then I'd say enjoy the A/C, although I would get one of the new rotary compressors. That's what I'm planning to do with mine. my 2 cents ................................that are sure to bashed to pieces by everyone who reads this!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/finger.gif) |
SLITS |
914GT |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region ![]() |
The Sanden SD 508 axial compressor (it's not really a rotary) does not require a lot of torque and would be better than the old York compressor for a 914/4. The compressor part number for HFC-134a is now V4509. If you keep the R12 setup and do what you need to in order to fix the leaks, a good R12 replacement is Freeze 12. A buddy of mine just used this in his airplane A/C and he said it worked great on his trip to Mexico last weekend.
ClayPerrine |
(IMG:http://www.914world.com/bbs2/html/emoticons/finger.gif) At least we still have some wide open spaces here. Back to the AC content.. ICEAC in california has a kit that is an absoulte bolt on for the type IV engine. It will work in a 914. I have one. It uses a modern rotary compressor and will work great with R-134a. I know, I just drove one with that kit not more than 20 minutes ago...... |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
If the AC works, or takes little to get it working - keep it. That is a big job filling up all the holes. I had one with A/C but didn't work so I chucked it. I am slowly filling up the holes and the biggun on the trunk floor.
The other sucky thing about the A/C is the hole in the trunk, it really weakens up that structure. But I haven't heard of a tub falling apart because of it either. In hindsight I would think twice about taking it out. Especially in your climate. |
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
I took mine out and sold it for a decent chunk of change. After taking it out I had some pretty big holes in the trunk to fill nad I also had to replace one of the engine tins. The tin was cut up to make room for the compressor. Mine is not a daily driver and I didn't like the way it cluttered up the interior. Even with the A/C working, it wasn't very fun to drive in 100 degree heat.
You can go to my blog and see before and after pics of the front trunk. |
carreraguy |
It's not your dad's 914! ![]() ![]() ![]() Group: Members Posts: 1,197 Joined: 17-October 03 From: San Jose, CA Member No.: 1,256 Region Association: Northern California ![]() |
I have A/C in my car but I had to disable it to make the front sway bar fit. So if you intend to drive it "aggressively" you may end up making the A/C inop regardless.
914rrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,835 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States ![]() |
There is a local guy who is making a new AC kit for 914's. Initial goals of the project are:
a small rotary compressor that will mount completely below the engine tin, will not require hacking up the engine shelf and have a simple, easy to adjust belt tensioner. custom evaporator unit will mount under dash and not require you to cut a stock height center console won't require you to hack up the front trunk floor "too" bad and hopefully still be able to store spare tire in the front trunk well ala DPD system. I'm trying to talk him into an inner quarter panel mounted condenser like Griffith uses for their 911 AC upgrade. The guy has been building and installing aircooled VW AC systems for years and knows what he's doing. My 73 2.0 may be the "photo model/ prototype" for the project. I had a DPD system in my old daily driver 74 2.0 w/ single 2 bbl weber. It would almost get TOO cold, even on hella hot Florida summer days. It wasn't much of a load on the engine. One advantage was being able to defrost / defog the windows on wet days in a matter of seconds. BTW, where is that old tech article about the diy 914-6 with AC? |
mistro |
Member ![]() ![]() Group: Members Posts: 148 Joined: 12-March 04 From: Highland Park, IL Member No.: 1,786 Region Association: None ![]() |
If this gets done, I'm the 2nd install! (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) Rgds, Michael |
bmcwilli |
Can I put in a sway bar with this AC?
Thx |
ewdysar |
What happens here, stays here. ![]() ![]() ![]() Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 ![]() |
I'd like to see pics of the custom under dash unit. I'm leaning towards the "original" wide unit, I prefer the way it looks over every after market one that I've seen.
Eric |
Automotive Hindenburg |
Newbie ![]() Group: Members Posts: 17 Joined: 20-April 05 From: Atlanta, GA Member No.: 3,955 ![]() |
I bought my car because it had AC, I would think that resell value would be higher if you kept it. My system has been converted to R-134 using a Sanden compressor and new hoses. It cools well and has very little drag.
On a side note, does anyone have a picture of the original compressor seals? I have the instructions that indicate that there was something installed around the compressor to seal it to the modified engine tins but it is missing on my car so a lot of hot air gets pulled up from the bottom of the motor. |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Didn't the Dealers just use a sticky goo type seal?
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,192 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Ive shred'ed about 4 so equiped cars and nary a one had such a seal remaining after 30 odd yrs. sticky or otherwise.
I dont get your comment about resale value. Once youve punched as many holes in the chassi as was required back then to install AC (on a Targa car (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) ) dont expect to get anywhere near the same value as the exact same car w/o. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Wouldn't that depend on the buyer? My next 914 (I will have two (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ) will have AC for those days that it is just to damn hot & muggy to drive with the top off the car. And if I had my choice it would be a white & red (orange?) LE car, just to piss everyone off (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 12:54 PM |
