CDR 23 Becker, anyone used one in a 914 ? |
porschetub |
Jun 13 2017, 05:09 PM
Advanced Member Group: Members Posts: 4,764 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
as per title,picked up one of these Becker really cheap,if they are crap tell me and it will go in my 944 which I'am selling.
TIA. |
ndfrigi |
Jun 13 2017, 05:11 PM
Advanced Member Group: Members Posts: 2,960 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
That should be nice in a 914 as long it will fit the original hole!
jim_hoyland |
Jun 13 2017, 05:14 PM
Get that VIN ? Group: Members Posts: 9,577 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I used a Becker 220CDR for years; it fit fine.
porschetub |
Jun 13 2017, 05:51 PM
I used a Becker 220CDR for years; it fit fine. Thanks guys,presume its standard DIN mount anyway ?,research indicates they have the ability to connect direct to speakers from one rear plug or another optional plug runs them thru a separate power amp which from then on was usually a Bose system...remembering this is a late model unit. |
JmuRiz |
Jun 13 2017, 07:00 PM
914 Guru Group: Members Posts: 5,522 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Should work, but if you want to get rid of it, let me know. My brother needs a head unit for his now-street-able 968 race car (IMG:style_emoticons/default/biggrin.gif)
jim_hoyland |
Jun 13 2017, 07:50 PM
Many Becker radios have a provision for an auxiliary input such as aCD changer or iPod. IIRC, the blue/green optional connector works with iPod. The user manual will identify all the plugs and pin outs.
theer |
Jun 13 2017, 08:53 PM
Senior Member Group: Members Posts: 686 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I could be wrong, but I thought only the CDR220 will work and then only as long as you have the activation "code".
The newer CDR23 gets the code from the car it was in (ecu? Gauge cluster?), so won't work in any other car. Would be cool if you got it to work... it will fit and looks great. |
porschetub |
Jun 14 2017, 03:03 PM
I could be wrong, but I thought only the CDR220 will work and then only as long as you have the activation "code". The newer CDR23 gets the code from the car it was in (ecu? Gauge cluster?), so won't work in any other car. Would be cool if you got it to work... it will fit and looks great. Thanks for your answer and you are 100% correct,only the cdr220 can be recoded as the code is stored in the headunit,the cdr23 gets its code from the cars ecu . Those units appear to have caused many owners issues if they are removed or the battery goes flat or is disconnected,some forums mentioned dealers were unable to help or suggested a replacement unit,sounds like a huge PITA. Because I purchased this in an auction I have the right to pull out of the deal and the seller is happy with this,no money lost so all's well. Thanks to all for answers. |
Lo-Fi Version | Time is now: 15th January 2025 - 02:12 AM |
