tabs914 |
Advertise Your Drive... ![]() ![]() Group: Members Posts: 105 Joined: 17-January 05 From: Gresham, Oregon Member No.: 3,456 Region Association: None ![]() |
It appears that my transmission is leaking from the tac plug connection. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Is there a seal right there or am I looking at deeper issues. Your input would greatly be appreciated. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
brp914 |
Unregistered ![]() |
20 yrs of teener-itis and dont know what a "tac plug connection" is. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Type 4 Unleashed |
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None ![]() |
He probally meant the speedo drive. It has an O ring, not a big issue. |
tabs914 |
OK speedo drive connection...thanks for the info. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Tab |
Red-Beard |
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None ![]() ![]() |
There is an o-ring on the speedo drive. If the leak is through the drive, get a new drive. If the leak is around the outside, change the o-ring at the next tranny oil change.
Be Warned! - There is a locking bolt holding it in place. The threads are a heli-coil and the thing gets tightened to three (3) Ft-lbs. More than that and you strip the helicoil. - Be Warned! |
Lo-Fi Version | Time is now: 27th June 2024 - 07:59 PM |
