Oil tank and engine oil cooler (3.2) fittings |
Biggles |
Jun 16 2017, 04:42 AM
Member Group: Members Posts: 197 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
Hi All
I'm in the process of fitting one of these Fumoto quick drain valves and need to get some braded AN oil line's made up Please can someone tell me the size of the male thread coming from a stock -6 oil tank, and also the size of the thread on the engine oil cooler - it's a 3.2 Carrera engine. They're both on the car at the moment so can't measure them. Thanks Chris |
mb911 |
Jun 16 2017, 06:40 AM
914 Guru Group: Members Posts: 7,151 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
30mm and 26 mm.
Biggles |
Jun 16 2017, 08:59 AM
Biggles |
mb911 |
Jun 16 2017, 10:16 AM
30 from tank to oil cooler and 26 from engine scavenge to oil tank return.
Biggles |
Jun 17 2017, 03:47 AM
mepstein |
Jun 17 2017, 04:05 AM
914-6 GT in waiting Group: Members Posts: 19,507 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
30 from tank to oil cooler and 26 from engine scavenge to oil tank return. Sorry to Labour the point but are they 30mm at both ends of the oil tank to engine oil cooler line on a 3.2 ? (That was the one I'm interested in) Thanks Yes If you want to run A/N hoses, you can get metric to A/N adaptors for the metric fittings. Then you aren't locked into the length of the metric hose if your building a non stock setup. |
Biggles |
Jun 17 2017, 04:40 AM
30 from tank to oil cooler and 26 from engine scavenge to oil tank return. Sorry to Labour the point but are they 30mm at both ends of the oil tank to engine oil cooler line on a 3.2 ? (That was the one I'm interested in) Thanks Yes If you want to run A/N hoses, you can get metric to A/N adaptors for the metric fittings. Then you aren't locked into the length of the metric hose if your building a non stock setup. Ok great. Cheers |
Biggles |
Aug 23 2018, 04:05 PM
what's the internal diameter on the oil line to the engine cooler on a 3.2 ?
Just getting around to doing this job and selecting the right Fumoto drain valve prior to taking everything apart. Also, can someone advise me if I have the oil flow right? Not sure I do (always learning!) cheers. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 21st September 2024 - 07:14 PM |
