80cap |
Member ![]() ![]() Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None ![]() |
What fire extinguisher do you guys carry?
Brian |
oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
Hi Brian, this is a repost of a product I found recently that you may want to consider:
I purchased the 6 foot BlazeCut Fire Suppression System. This length only requires one length down one side of the lid, one curve, and one length back the other side of the lid. I also found that the stiff tubing does not like to bend into a tight enough arc to fit into the confines of the engine lid. The tube kinked at the center of the curve, but I don't think it damaged it. I bought an electrical gray pipe curve, 3/4" ID, split it with my band saw, and zip tied and taped it around the BlazeCut tubing at the center of the arc where the tubing wanted to kink. This supported and held the tubing, keeping the tubing in the required arc while preventing it from kinking. I also found that plastic zip ties were not strong enough to hold the tubing in position under the engine lid. The stiff BlazeCut tubing does not like to bend or go where you want it to very easily. As you can see, I removed my rain tray a while ago since I never take the car out in bad weather and the engine runs cooler without it. I fastened the tubing to the underside of the engine lid using metal pipe claps, 3/4 ID, and short self tapping metal screws into the lid supports. I wrapped the BlazeCut in heavy plumbers tape wherever it came in contact with the metal lid. I also cut thin strips of black tape and put them on the top side of the BlazeCut tube so you could not easily see the white tubing through the engine grill from the outside. If you look on the left side of my engine lid, you can also see a steel braided cable I added a while back so I don't have to hold on to the engine lid when I open it. Without the cable, if you popped the engine lid and didn't hold it, it would fly open and put a lot of bending force on the hinges, which I have already rewelded once. Now the cable catches it before it works on the hinges. BTW, if you have a weak opening engine cover, here's a link to an easy and simple fix that lets you put more pop in the opening, especially with the extra weight of the BlazeCut under the lid. My lids pops open fully now, even with the tubing under it. http://www.914world.com/bbs2/index.php?sho...=290514&hl= I hope I never have to find out how well the BlazeCut tubing works! ![]() ![]() |
Porscheguy912 |
porscheguy912 ![]() Group: Members Posts: 46 Joined: 10-April 14 From: Summit, NJ Member No.: 17,236 Region Association: North East States ![]() |
Dear Brian, I also have BlazeCut in my 912 soft-window and 914.
Gregory |
designerguy90 |
Member ![]() ![]() Group: Members Posts: 52 Joined: 21-July 14 From: Chicagoland Member No.: 17,666 Region Association: None ![]() |
I have one of the 2.5lb H3R Hal Guard clean agent extinguishers in my 968 and 914.
80cap |
Thanks
Brian |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
1.5kg with motorsport approved stainless mount,haven't fitted it yet cause I can't decide where (IMG:style_emoticons/default/headbang.gif)
AZBanks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region ![]() ![]() |
Get a clean agent like Halon(if you can find it) or halotron.
There are several vendors who carry these kinds of extinguishers. Normal household extinguishers use chemicals that are very corrosive and damaging to most car parts. It would be a huge bummer to save your car from a fire and then have to replace most of the car due to damage from the extinguisher you used. |
db9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None ![]() ![]() |
Blazecut 3 meter version.....lay it in the sun a little while to soften and it will make the bends needed.
http://www.914world.com/bbs2/index.php?sho...amp;hl=blazecut |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,999 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
What I [do carry is a 5-lb hand-held bottle of Halon. It was the minimum required by the local track outfits when I got it. Halon is harder to find now, but there are similar alternatives available that have better or worse reps.
The AFFF (aqueous fire-fighting foam or something like that) sounds like a pretty decent way to go now. Many of the dry chemical agents are hugely corrosive to aluminum, magnesium, and wiring, so it's best to stay away from those. --DD |
eitnurg |
Country Member ![]() ![]() Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None ![]() |
Halon has been banned for several years now: although it's excellent at putting out fires, it was also found that it's even better at destroying the ozone layer.
There are still a few halon extinguishers around, they are still allowed in aviation and the military as there's simply nothing better. So if you see one, grab it: but don't expect to be able to get it re-charged at all. |
Coondog |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California ![]() ![]() |
Halon has been banned for several years now: although it's excellent at putting out fires, it was also found that it's even better at destroying the ozone layer. There are still a few halon extinguishers around, they are still allowed in aviation and the military as there's simply nothing better. So if you see one, grab it: but don't expect to be able to get it re-charged at all. Actually Halon is only banned from industry producing more Halon. You can still buy Halon but be prepared to pay $$$$$. If you have a Halon ext. treat it like Gold as it's a wanted commodity because it can no longer be made but old Halon can be sold over and over again. I have a Halotron ext. in my 914 for Elec fires and a purple K extinguisher for fuel fires. |
porschetub |
Halon was banned in my country yrs ago,my one is dry power hope that's useful,no expert so don't know.
The days of expecting fuel hose to last for a long time are long gone,who knows what grap they will add to fuel in the future,I use EFI hose on my carbs anyway but always check over and use proper fuel line connectors....no screw clamps (IMG:style_emoticons/default/dry.gif) . |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
I have Halon extinguishers my Porsches and automatically deployed halon extinguishers in my Motorhome. However, if I were buying today, I'd look into the foam extinguishers as they will smother the fire and cool the area to hopefully prevent reigniting the fire from the heat. Only problem is that the foam extinguishers can freeze (for those of us that live in the northern states).
AZBanks |
Sadly, halon was banned based on the “Ozone Shield” myth that blamed freon gas for destroying this mythical shield with a chemical reaction that has never observed in nature or in a laboratory.
porbmw |
Senior Member ![]() ![]() ![]() Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None ![]() ![]() |
[quote name='AZBanks' date='Jun 21 2017, 07:16 PM' post='2498981']
Sadly, halon was banned based on the “Ozone Shield” myth that blamed freon gas for destroying this mythical shield with a chemical reaction that has never observed in nature or in a laboratory. [/quote Yup And global warming, and man's contribution to it, is all a myth as well... BTW What is the outside temp in Phoenix these days..... (IMG:style_emoticons/default/poke.gif) |
914dave |
914 Addict ![]() ![]() ![]() Group: Members Posts: 710 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States ![]() ![]() ![]() |
914dave |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
SPA...
Attached image(s) ![]() ![]() ![]() |
Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,198 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
Halon is the way to go. You can find them at aircraft supply stores. Also, watch for Zoro 25-30% sales, that is when I stock up on things like fire extinguishers. Bigger is always better.
Blazecut seems like a good initial defense, not sure if it contains enough agent to put out a fuel fire. Which leads to the fact that the best way to deal with fire is prevention. If funds are limited, replace any old fuel lines, injector hoses, etc. before spending money on an extinguisher. |
70Sixter |
Member ![]() ![]() Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States ![]() |
Lo-Fi Version | Time is now: 24th June 2024 - 11:53 PM |
