> Eastwood Stripping Tool, Paint Stripping
Highland
post Jun 26 2017, 04:36 PM
I was just wondering if anyone has ever used this tool. The demo videos make it seem very easy to strip a car of unwanted old paint.
http://www.eastwood.com/eastwood-contour-sct.html
Replies(1 - 11)
cn2800
post Jun 26 2017, 05:55 PM
I wonder if it works well for undercoating.
rgalla9146
post Jun 26 2017, 06:59 PM
Check out the cost of the various abrasive drums.
post Jun 26 2017, 07:15 PM
914-6 GT in waiting
We have one at the shop. It works pretty well but tools always look better in the manufacturers videos.
john77
post Jun 27 2017, 12:46 AM
I was looking at the sct but decided against it because the drums were so damn expensive. Ended up getting a Porter Cable restorer instead. It's pretty much the same thing, only it's half the price and the black stripping drums are $20 instead of $60. I stripped 3/4 of a car last year using drills, angle grinders, air grinders, and every type of attachment imaginable and the quick test I did with the restorer took paint off better than anything I've ever used before. Not saying it's a miracle cure, it still takes time, but I was impressed with how quick it tore through paint and a layer of bondo down to bare metal.
mgphoto
post Jun 27 2017, 12:11 PM
"If there is a mistake it will find me"
Wurth DBS 3600, a bit pricey.
Many different brushes.Attached Image
Other vendors have the same unit priced less. Dent-Fix
Mike
Highland
post Jun 27 2017, 01:58 PM
Thanks for all the input.
The Porter seems like a more affordable option.
Eastwood says you can do a small car like the 914 with 2 black drums. I was expecting more like 10+ drums. Does 2 or 3 sound reasonable?
Garland
post Jun 27 2017, 04:37 PM
Restoration Fanatic
I think that would depend on how much paint has been put on the car.
restore2seater
post Jun 27 2017, 07:03 PM
Future 914 copilot.
The guy is a little long winded but might want to check this review.
Porter-Cable vs. Eastwood SCT
ConeDodger
post Jun 27 2017, 07:28 PM
Apex killer!
QUOTE(rgalla9146 @ Jun 26 2017, 09:59 PM) *
Not to mention the possibility of going through one of those drums every fifteen minutes or so... (IMG:style_emoticons/default/blink.gif)
Matty900
post Jun 27 2017, 09:40 PM
I used the Eastwood pneumatic Rotary Removal tool last Friday to do this. I would highly recommend it if you have a compressor to run it off of (7CFM [100L/min]
It was great for getting through all of that seam sealer.
914forme
post Jun 29 2017, 06:59 AM
Dynabrade - DynaZip
Less than the Worth, more than the Eastwood, Eastwood did not have theirs out when I purchased this unit.
Use it all the time, cleans up welds if your using flux-core, which I only do on large thick metals. Strips seams sealer like, it is not even there, only tool I have found that does that. It will just cut into it, and start flinging little bits of it, until you are down to clean metal and have a huge pile of that seam sealer on the floor.
Undercoating, not an issue
Proper tool for the job, I need to start a business just to cover my tool costs, as a hobby this is way to expensive. (IMG:style_emoticons/default/dry.gif)
- Lo-Fi Version Time is now: 27th November 2024 - 07:31 PM
