amfab |
Member ![]() ![]() Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None ![]() ![]() |
I am looking for a seat belt nut/reinforcement thingy in the longitudinal.
I need one, and was wondering if anybody makes this. I am sure I can probably fab something up, but it would be one less thing on my list if someone already makes one. TIA -Andrew |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
in the US, 99% of cars have a 7/16"-20 thread pitch for the seatbelt. So you might be able to find any type of vehicle repair nut and make it work.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
VW aircooled bug shop.
Mike Bellis |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Do you have a bolt that threads into it? If so, take it to your local hardware store and find a nut that fits.
Mark Henry |
I forget the pitch, but IIRC it's an oddball, you could try Fastenal or Bell metric.
That said I'm pretty sure about a bug shop having the repair bit. 914 has the same hardware as a 70's bug. |
Mark Henry |
cip1 sells these, I thought they would be metric (IMG:style_emoticons/default/confused24.gif)
http://www2.cip1.com/ProductDetails.asp?Pr...ode=C27-SEC6814 http://www2.cip1.com/ProductDetails.asp?Pr...e=C45-20304-SET |
Rand |
Or if you are replacing it anyway, find a standard but appropriate bolt and nut pair at your hardware store. Not even a CCW would catch it. (I hear the voices of purists talking about tensile strength, yada. Buy quality hardware. I just hate it when there are super specialized parts that don't need to be.)
Mark Henry |
in the US, 99% of cars have a 7/16"-20 thread pitch for the seatbelt. So you might be able to find any type of vehicle repair nut and make it work. You're right! Even on euro cars, due to US mandated standards. I didn't know that. (IMG:style_emoticons/default/popcorn[1].gif) Here's a C&P from the samba QUOTE rsxsr wrote: Seatbelts use a unique bolt. It is a strong grade and odd thread pitch so that you can't accidentally put in cheap hardware. 7/16" SAE fine-thread grade 8 bolt/nut are utilized throughout the North American Vanagon Seat Belt system... Kinda weird on a metric built automobile.... Metric bolts and nuts get close to fitting but are a NO-GO. The 7/16" SAE fine thread grade 8 stuff works 100%. Wink So far in my searches.. I have not located a square nut in this size?... I've used hex nuts in my repairs of this ongoing problem. Begs the question: are European Transporters using this SAE bolt system on the seat-belts? Pz I can't say for sure, but probably so. the US safety standard FMVS209 stipulates the size of 7/16-20 or equivalent. So you will find this same size on many non-US cars - European and Asians ones too, at least on models heading to the US. I suspect that many non-US models still use the 7/16-20 size as well. The Asians ones seem to "cheat" - but just by a hair, literally. My measurements indicates they are probably using M11-1.25 - only about 0.003" difference. (Note, not really cheating - it is equivalent) Strength is indeed grade 8 which is the same as the metric property class 10.9 (150,000 psi / 1040 MPa - same hardness of HRC 33-39), so some of the European companies put 10.9 on the head. GM switched to M12-1.75 seat belt bolts several years back, but their global spec is 7/16-20 now - per the request of their non-US divisions! |
amfab |
You guys all rock!
Thank you |
Lo-Fi Version | Time is now: 20th June 2024 - 05:44 AM |
