SOLD...Complete 73'-74' 2.0L Engine in pieces with complete D-Jet F.I. system |
Dominic |
Jul 28 2017, 05:14 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
SOLD!
I have one complete Used 73' - 74' 2.0L engine in pieces (boxes): $1500.00 obo plus shipping (delivery available in Northern California) SOLD! What is included in price: Engine: GA Case (STD) (including studs, through bolts, taco plate/sender, oil baffle) 2.0L Crank (STD)/ Rods (impeller hub included with crank) 73' - 74' 2.0L Pair of Heads Push rods / tubes Oil Pump (choice of stock or steel 30mm HD pump) Oil cooler / oil filter stand both sides 2.0L cooling tins Aluminum fan shroud w/flaps (4) 94mm KS German Flat top pistons/cylinders 2.0L D-Jet pieces included: 2.0L Air filter housing 2.0L Plenum with sensors, cold start valve, aux air regulator and throttle body 3 bolt intake runners Bosch 043 Manifold Pressure Sensor 2.0L Green Bosch Fuel Injectors, rails and fuel pressure regulator 2.0L D-Jet Ecu and Harness I'm sure I'm forgetting something but all of the little parts will be included (Sorry no flywheel or impeller fan) All parts are used but in rebuildable condition. More Pics of the D-Jet system will be added tomorrow. Attached thumbnail(s) |
Dominic |
Jul 29 2017, 12:40 PM
D-Jet F.I. Pics...
Dominic |
Aug 8 2017, 10:32 AM
Bump! Make me a reasonable offer if you need a complete engine
rob_e |
Aug 9 2017, 07:50 AM
I'm new here ... Group: Members Posts: 0 Joined: 6-June 17 From: UK Member No.: 21,155 Region Association: None |
what condition are the heads in? would you sell those separately?
Dominic |
Aug 9 2017, 08:40 AM
Dominic |
Aug 22 2017, 10:33 AM
Dominic |
Sep 19 2017, 09:17 PM
BUMP!
Puebloswatcop |
Sep 21 2017, 10:45 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
are the FI parts available seperately
Dominic |
Sep 22 2017, 08:15 AM
Puebloswatcop |
Sep 25 2017, 01:09 PM
Lo-Fi Version | Time is now: 25th June 2024 - 09:36 PM |
