mmascari |
Member ![]() ![]() Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None ![]() |
Does anyone know of a source for a gauge pod that fits in to the ashtray? Thanks.Mark
michael7810 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region ![]() ![]() |
Rennmetal makes the one I have. Holds 2 gauges.
mmascari |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
VDO made just such an item way back when.....
I have one. It's a hard rubber or plastic item. Let me get you some pics. |
michael7810 |
Rennmetal makes the one I have. Holds 2 gauges. Thanks.....you don't happen to have a web link? Hmmm. They were a vendor on this site a few years ago it I can't find a link either. I can look thru my paperwork at home but I won't be there for 3 weeks. Hopefully someone can help before that. It's a simple design. Literally an L shaped bracket with 2 mounting holes on the short leg and 2 gauge holes on the long leg. Remove the 2 screws that hold the ashtray mount to bottom of dash and install L gauge mount. I moved mine to under the dash using the same mount shown below. ![]() ![]() |
mmascari |
SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
VDO made one I've had in my '71 since the early '70's. Don't know if they still make it. Fits perfectly where the ashtray was...
Thought I had a better picture but can't find it- sorry for lousy image, but you can barely see it.. ![]() |
mmascari |
VDO made one I've had in my '71 since the early '70's. Don't know if they still make it. Fits perfectly where the ashtray was... Thought I had a better picture but can't find it- sorry for lousy image, but you can barely see it.. ![]() That's exactly what I am looking for. Hope someone knows where to get one. |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
SKL1 |
It's a "rubberized" pod- maybe metal inside but definitely not metal on the outside. Does not look like the one just above. My picture doesn't show it well, but it does have an angled part on the top that could be shaved off.
mmascari |
VDO makes a nice rubber one that fits nicely. You do need to cut off the angled top section and drill holes to use the ashtray mounting holes, but it fits nicely. They ar still listed in the VDO catalog, so should still be available. If not, a two gauge metal racket is also available. ![]() That's perfect...thanks George. I will try and find one. |
mmascari |
This one actually looks like the one George has: https://www.vdo-gauges.com/accessories/inst...-16-gauges.html |
HalfMoon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region ![]() |
Does anyone know of a source for a gauge pod that fits in to the ashtray? Thanks.Mark Not to (IMG:style_emoticons/default/hijacked.gif) but I wonder if anyone makes a gauge pod that attaches to the left side windshield pillar? |
Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
Not to (IMG:style_emoticons/default/hijacked.gif) but I wonder if anyone makes a gauge pod that attaches to the left side windshield pillar? http://shop.914rubber.com/A-Pillar-Gauge-p...p3plqscsfapp004 |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Does anyone know of a source for a gauge pod that fits in to the ashtray? Thanks.Mark Not to (IMG:style_emoticons/default/hijacked.gif) but I wonder if anyone makes a gauge pod that attaches to the left side windshield pillar? I think 914rubber.com offers this. http://shop.914rubber.com/A-Pillar-Gauge-panel-914APG.htm No affiliation. I just happened to see it while browsing. |
GeorgeRud |
VDO part number 240 803 is the rubber mounting two gauge bracket (though the picture is wrong). It's available directly through VDO on their website. Summit Racing carries the metal bracket.
HalfMoon |
VDO part number 240 803 is the rubber mounting two gauge bracket (though the picture is wrong). It's available directly through VDO on their website. Summit Racing carries the metal bracket. Also Walmart online (free shipping) for $12.50 https://www.walmart.com/ip/VDO-240-028-Moun...auges/198720014 |
HalfMoon |
Not to (IMG:style_emoticons/default/hijacked.gif) but I wonder if anyone makes a gauge pod that attaches to the left side windshield pillar? http://shop.914rubber.com/A-Pillar-Gauge-p...p3plqscsfapp004 Awesome dat |
mmascari |
VDO part number 240 803 is the rubber mounting two gauge bracket (though the picture is wrong). It's available directly through VDO on their website. Summit Racing carries the metal bracket. I called Summit Racing and was told the rubber bracket that holds two is no longer available. VDO no longer makes it. |
Lo-Fi Version | Time is now: 30th June 2024 - 07:01 PM |
