> Rev limiting rotors
Sea Dragon 914
post Sep 10 2017, 12:13 PM
I'm looking for a Bosche rev limiting rotor for my 914 2.0. I recall there was one that was either 6300 or 6500 rpm. Does anyone know where to find them and what the part number is?
Replies(1 - 6)
Mark Henry
post Sep 10 2017, 12:25 PM
that's what I do!
QUOTE(Sea Dragon 914 @ Sep 10 2017, 02:13 PM) *
I imagine Pelicanparts have them.
Even in race trim the type 4 runs out of torque at 5800rpm. 63-6500rpm will require dual springs, HD valvetrain, balanced engine, etc.
Do not use these rotors as a shift indicator, loading and unloading the engine with a rev-limiter will destroy your bearings, etc in short order if you use it this way.
A rev-limiter is the lesser of two evils, a last ditch protection device.
mgphoto
post Sep 10 2017, 12:58 PM
"If there is a mistake it will find me"
911 rotor cuts out at 6300, fits the shaft.
Mike
914Sixer
post Sep 10 2017, 01:08 PM
914 rotors are set at 5800 rpm, same as the redline on the tachometer. Autohausaz.com $30.77
injunmort
post Sep 10 2017, 02:58 PM
partsgeek
DM_2000
post Sep 10 2017, 03:32 PM
Something to remember as it sometimes get lost. A rev limiter won't help a mechanical over rev ( 3 / 2 rather than a 3 / 4 ) or if a shift is missed completely and inertia carries the motor past the rev limiter.
Sea Dragon 914
post Sep 10 2017, 05:44 PM
Thanks. I thought the old 911 rotors worked but I wasn't sure. I have an engine that is balanced with mild cam and heavy springs. Just need it as as safety measure.
My throttle cable stuck and the RPMs shot to 7k. I replaced the cable and everything seems ok. I don't think there is any damage as it feels like I still have 4 cylinders firimg.
- Lo-Fi Version Time is now: 4th January 2025 - 06:56 PM
