> ATE Master Cylinder Question
Ed_Turbo
post Sep 23 2017, 04:49 PM
Quick question, I noticed a hole on the rubber boot. Anyone with knowledge about these Master Cylinders know if this is normal? Looks like a hole to relieve air. Just want to double check before installing, thanks. (IMG:style_emoticons/default/beerchug.gif)
Replies(1 - 11)
DM_2000
post Sep 23 2017, 05:07 PM
I've seen this on other brands or they at least have a groove / hole at the end of the master cylinder. ( hole pointing down. )
If the last seal in the MC leaks brake fluid, these holes let it leak out signaling a problem.
Ed_Turbo
post Sep 23 2017, 05:52 PM
QUOTE(DM_2000 @ Sep 23 2017, 04:07 PM) *
That makes sense (IMG:style_emoticons/default/idea.gif)
914Sixer
post Sep 23 2017, 08:02 PM
Hole goes down. Weep hole to let you know you have a problem.
Ed_Turbo
post Sep 23 2017, 09:18 PM
QUOTE(914Sixer @ Sep 23 2017, 07:02 PM) *
Actually it points to the side not down.
I think I am just making too much of a big deal out of this (IMG:style_emoticons/default/laugh.gif)
porschetub
post Sep 23 2017, 10:12 PM
QUOTE(Ed_Turbo @ Sep 24 2017, 03:18 PM) *
Basically it is a breather for the bellows as they are tight fit on the rod and cylinder ...just not an issue go well you will be fine (IMG:style_emoticons/default/beer.gif) .
post Sep 24 2017, 11:36 AM
QUOTE(porschetub @ Sep 23 2017, 09:12 PM) *
That's what I was thinking, too. The fluid will find its way out one way or another. (IMG:style_emoticons/default/beerchug.gif)
porschetub
post Sep 24 2017, 02:20 PM
QUOTE(76-914 @ Sep 25 2017, 06:36 AM) *
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) think the OP found that out already with his old one (IMG:style_emoticons/default/headbang.gif) .
Mikey914
post Sep 25 2017, 01:57 AM
The rubber man
It's for air
The cylinder should not leak here ................... wait for it .................................
Unless it's a URO and it will pump all your fluid out this hole providing no braking whatsoever
GeorgeRud
post Sep 25 2017, 08:49 AM
I'd assume that it's there to just provide release for air, but having brake fluid coming out would definitely tell you it's time for a new one.
Ed_Turbo
post Sep 25 2017, 04:11 PM
Quick update:
E-Mailed ATE and a german guy told me the hole is normal (he said 1.5mm). The hole is for air to release during operation and should be pointed down.
For those who said it was for air good job (IMG:style_emoticons/default/first.gif)
IronHillRestorations
post Sep 25 2017, 06:08 PM
I. I. R. C.
If it leaks you don't know it until your brakes go bad or you notice the MC level is low. You really can't see the fluid leaking on the floor until it get catastrophic, the pedal board is in the way.
- Lo-Fi Version Time is now: 26th December 2024 - 07:13 AM
