Weber 40 IDF carbs, 2 barrel made in Spain, SOLD |
IronHillRestorations |
Sep 25 2017, 10:53 AM
I. I. R. C. Group: Members Posts: 6,733 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Pair of Weber 40 IDF carbs, 2 barrel
Made in Spain, includes 2 different linkages, a hex bar set up which doesn't include any cable bracket, and a home made center pull bellcrank set up that has an integral cable bracket. These came off a running engine purchased from Robert Viceral (Exulatant1) that I put in a customer's car. I personally have not run these carbs. Both carbs have a cracked threaded boss that doesn't effect function. It's in the exact same place on both, so I wonder if it's a casting flaw. I'd recommend putting a gasket kit in these before you put them on your car, but that's your call. They both have the cold start mechanism. SOLD |
Sep 25 2017, 10:55 AM
detail
Attached thumbnail(s) |
Sep 25 2017, 10:57 AM
cracks
Sep 25 2017, 11:02 AM
Linkages The hex bar was on my customer's car and replaced with a CSP set up, the home made set up came on the engine.
Oct 2 2017, 07:21 AM
Empi type 4 carb manifolds. 46mm port at the top and 36mm at the bottom.
I"ve added these manifolds to this package, for the same price Attached thumbnail(s) |
Oct 7 2017, 06:11 AM
Even lower price, now $240
Lo-Fi Version | Time is now: 18th June 2024 - 07:47 AM |
