Carbs pop sometimes |
PanelBilly |
Sep 30 2017, 10:47 AM
914 Guru Group: Members Posts: 5,840 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I'll be driving along at a steady pace and I'll hear a pop. Any idea what's going on?
Running a 3.0 with PMOs |
rhodyguy |
Sep 30 2017, 11:15 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Sound from where? Tail pipe or burping back thru a carb?
PanelBilly |
Sep 30 2017, 12:14 PM
Carbs. Might be a backfire. Not very loud.
rhodyguy |
Sep 30 2017, 12:27 PM
Take the filters off and see if you can get one of the venturi to sneeze. Does it happen at the same rpm consistently?
PanelBilly |
Sep 30 2017, 01:01 PM
I'll need to check. What do you mean "sneeze"?
GeorgeRud |
Sep 30 2017, 02:53 PM
Usually you start looking if the timing is too advanced or the engine is running lean. However, that will usually cause a fairly constant backfire through the carb, not just an occasional one.
IronHillRestorations |
Sep 30 2017, 03:35 PM
I. I. R. C. Group: Members Posts: 6,761 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Pull the idle jets and soak them in carb cleaner.
Lo-Fi Version | Time is now: 27th September 2024 - 10:24 AM |
