Where does this vacuum line come from?, 1976 2.0 |
l.a.brooks |
Oct 19 2017, 12:05 AM
Newbie Group: Members Posts: 4 Joined: 24-October 14 From: Oregon Member No.: 18,052 Region Association: None |
Just put the engine back in our 1976 2.0 and I can't figure out where the vacuum line that connects to this valve comes from. Looking at the parts diagram it looks like it might connect to a boot or rubber fitting that connects below the air filter housing.
Not sure if there was a hose connected to this valve when we pulled the engine. It is the connector without a hose in the center of the photo. Also the charcoal filter was just sitting next to the battery with no mounting bracket - where is the bracket supposed to mount? Thanks for any help! |
Dave_Darling |
Oct 19 2017, 01:40 AM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
That's your Decel Valve. The small line connects to an F-shaped connector that hooks up to the plenum. (AKA manifold, or intake air distributor, or That Thing The Throttle Valve Sits On Top Of.)
If you don't have the F-shaped fitting, you can fake up something that works out of plumbing supplies. --DD |
l.a.brooks |
Oct 20 2017, 12:25 AM
That's your Decel Valve. The small line connects to an F-shaped connector that hooks up to the plenum. (AKA manifold, or intake air distributor, or That Thing The Throttle Valve Sits On Top Of.) If you don't have the F-shaped fitting, you can fake up something that works out of plumbing supplies. --DD Thanks, we put a T in one of the vacuum lines on the plenum today. I was concerned that there was another vacuum port for it somewhere that would be a leak if it wasn't connected or plugged. |
Mikey914 |
Oct 20 2017, 01:54 AM
The rubber man Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If you decide you want something more original -
http://shop.914rubber.com/searchquick-subm...eywords=stacked Attached thumbnail(s) |
GregAmy |
Oct 20 2017, 06:27 AM
Advanced Member Group: Members Posts: 2,314 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
oakdalecurtis |
Oct 20 2017, 08:14 AM
Oakdalecurtis Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Mikey914 |
Oct 20 2017, 10:42 AM
If you decide you want something more original - Is there anything for these cars you can't make...? I was looking for one of those last year...I think I'll just set 914Rubber.com as my browser home page and be done with it... We're actually declining contract manufacturing to double down on the 914 parts, so soon to say we have everything but body in white. (IMG:style_emoticons/default/biggrin.gif) |
914_teener |
Oct 20 2017, 11:17 AM
914 Guru Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
If you decide you want something more original - Is there anything for these cars you can't make...? I was looking for one of those last year...I think I'll just set 914Rubber.com as my browser home page and be done with it... We're actually declining contract manufacturing to double down on the 914 parts, so soon to say we have everything but body in white. (IMG:style_emoticons/default/biggrin.gif) I still think RD Design should do HE half shells. Steel Rule Die run? (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:41 AM |
