freezing14 |
freezing14 ![]() ![]() Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 ![]() |
that was on my 2.0 parts car,, the engine will be running after the guide job,, but should i put that muffler back with the 2.0,, and what is it from,, it just says KADRON made in bresil???
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Got a pic???
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,691 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
didn't KADRON make carbs for beetles? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
freezing14 |
something went funny when i uploaded the picture,, here it is
Attached image(s) ![]() |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
if "need" a muffler, that'll work, but I think you'd be better off throwing that thing away and put on a factory or a Bursch setup.....or go with a Traid if you have 2.0 heatexchangers (not sure if they make 1.7/1.8 mufflers)
freezing14 |
I do not have the heat exchanger, just some sort of headers, with a flange at the end
Mueller |
at the end or ends?? if dual, you might have heat exchangers with the ducting removed....pretty common for rusty HE's if the muffler you posted bolts up, you have modified heat exchangers.... a /4 header will have all 4 tubes converge into one tube |
Lo-Fi Version | Time is now: 18th June 2024 - 07:40 AM |
