Steering column paint color, Steering column |
simonjb |
Jan 7 2018, 08:30 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Mine has some scratches. Has anyone painted theirs? If so, what color did you use?
bbrock |
Jan 7 2018, 08:43 PM
I haven't done the column yet but will be soon and have repainted the instrument panel and other trim. I used EDIT: SEM trim black (#39143)based on recommendations from folks here. That's what I'll use for the steering wheel and column too.
gothspeed |
Jan 7 2018, 10:55 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I disassembled down to the bare shells and had them powder coated satin black. Had to replace the ignition switch and converted the windshield washer portion to an electric switch for pump.
iankarr |
Jan 8 2018, 12:55 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,526 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
On my '73 I used rustoleum satin black. Close match but it's not as durable as powder coat. If you do decide to use powder, def test the color first. The "satin black" from Eastwood is almost flat, Their semi-gloss is a lot closer.
Lo-Fi Version | Time is now: 26th December 2024 - 05:02 PM |
