1adam12 |
Member ![]() ![]() Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California ![]() |
I took my injectors out of my '72 1.7l over the weekend and found that the PO used RTV gasket sealant to seal off the #2,#1 fuel injectors (IMG:style_emoticons/default/dry.gif) Upon further inspection, I noticed that the stepped o-ring/grommets where missing. I purchased an injector o-rings set from my local auto store thinking that would be it but nope. Can someone please tell me what that o-ring/grommet is called and where I can purchase them?
It's placed in the bottom opening of the intake runners where the injector is installed. |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
Here's a link to pelican which has the small seal (the one you're referencing) and the large seal which goes around the wide part of the injector.
https://www.pelicanparts.com/cgi-bin/ksearc...n=injector+seal |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Post up some pics,
I may have what you need. Mark |
1adam12 |
Thanks Gents! I'll check through Pelican.
Mark, I checked through your website first and didn't see anything but here's a pic of the piece. Looks like I'll have to replace all 4 since the existing ones are cracking. Attached thumbnail(s) ![]() ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
If you decide to send out your injectors to be cleaned, mr injector replaces all the rubber parts in the $17.50 price.
1adam12 |
CuddyK I looked through Pelican and I didn't find it. Only found grommet plugs, gaskets and the upper and lower seals to the injector.
iankarr |
If Mark / Mikey and 914rubber has these, def buy from them!
1adam12 |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Those are not type 4 injector seals. 914 seals do not have a lip.
TheCabinetmaker |
Actually, those are not seals. They are just spacers to hold the injector in place. The small ones are the actual seals.
1adam12 |
Those are not type 4 injector seals. 914 seals do not have a lip. This grommet/seal actually installs in the injector port on the intake runner... well at least on my #3, and #4 injectors. It seemed that it was factory because the injectors fit much more snug and the grommet/seal fit flush in the base of the runner. I rather be 100% sure on this as it's on my set up and the PO used gasket sealant on the injectors that did not have this grommet. |
1adam12 |
TheCabinetmaker |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
I took my injectors out of my '72 1.7l over the weekend and found that the PO used RTV gasket sealant to seal off the #2,#1 fuel injectors (IMG:style_emoticons/default/dry.gif) Upon further inspection, I noticed that the stepped o-ring/grommets where missing. I purchased an injector o-rings set from my local auto store thinking that would be it but nope. Can someone please tell me what that o-ring/grommet is called and where I can purchase them? It's placed in the bottom opening of the intake runners where the injector is installed. Rock Auto has them real cheap http://www.rockauto.com/en/catalogRock Auto injector seals |
1adam12 |
Thanks folks! I'll order some through the recommended dealers.
Mikey914 |
Sorry didn't get to posting up, but looks like these are available, and inexpensive.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
1adam12 |
I think what's throwing me off is that the O-rings that I posted pics of looked nothing like the fuel injector lower seals that I just purchased. I'm just presently learning through someone else's ghetto rigging this 1.7l. Now it makes sense why the the #2 and #1 injectors had only RTV gasket seal sense the previous owner just scraped together whatever seals they could for the present injectors.
I'll be placing the new factory replacement upper and lower seals on my injectors tonight. I'm surprised I didn't see any fuel leakage. Well, One Fix At A Damn Time! Purchased car back in May and haven't even driven her yet. |
JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,933 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
I think what's throwing me off is that the O-rings that I posted pics of looked nothing like the fuel injector lower seals that I just purchased. I'm just presently learning through someone else's ghetto rigging this 1.7l. Now it makes sense why the the #2 and #1 injectors had only RTV gasket seal sense the previous owner just scraped together whatever seals they could for the present injectors. I'll be placing the new factory replacement upper and lower seals on my injectors tonight. I'm surprised I didn't see any fuel leakage. Well, One Fix At A Damn Time! Purchased car back in May and haven't even driven her yet. They look nothing like the lower seals you purchased because the ones that were on the car had 40 years of pressure and heat from the heads applied to them. They all wind up looking like that eventually. The stepped shape is what they look like pressed in place, those ones have just been baked so long they no longer spring back. |
1adam12 |
I think what's throwing me off is that the O-rings that I posted pics of looked nothing like the fuel injector lower seals that I just purchased. I'm just presently learning through someone else's ghetto rigging this 1.7l. Now it makes sense why the the #2 and #1 injectors had only RTV gasket seal sense the previous owner just scraped together whatever seals they could for the present injectors. I'll be placing the new factory replacement upper and lower seals on my injectors tonight. I'm surprised I didn't see any fuel leakage. Well, One Fix At A Damn Time! Purchased car back in May and haven't even driven her yet. They look nothing like the lower seals you purchased because the ones that were on the car had 40 years of pressure and heat from the heads applied to them. They all wind up looking like that eventually. The stepped shape is what they look like pressed in place, those ones have just been baked so long they no longer spring back. Thanks JamesM. Makes sense why they fit so perfectly in the heads. 40 year molding process! |
Lo-Fi Version | Time is now: 26th June 2024 - 04:12 AM |
