Recommend an Impact Wrench/Gun |
stateofidleness |
Feb 14 2018, 07:01 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
Hey all, had a run-in with a pretty stubborn set of axle nuts (F150 with 200k miles) the other day, and ended up shearing 4 breaker bars! (varying lengths and "quality" of bars). Ultimately ended up having to put a pipe wrench my dad has (HUGE wrench from his gas line inspecting days with Valero) and a cheater bar.
I'm a huge advocate of "use the right tool for the job" though, so I'm curious if any of you guys can make recommendations for a "holy grail" impact gun that won't flinch at anything car related. My nice to haves: - $200-$400 range preferred - Electric (battery) or Air (preferred) - assume a really good air compressor/tank to drive it - Break loose anything I could encounter on a vehicle - Re-torquing lower priority as that will be by hand and/or torque wrench anyway Spent couple days researching stuff and Ingersoll Rand seems to get very good reviews. Can anyone recommend something meeting the above preferences? |
76-914 |
Feb 14 2018, 07:10 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,650 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Earthquake at Harbor Freight for the occasional user.
914Sixer |
Feb 14 2018, 07:40 PM
914 Guru Group: Members Posts: 9,040 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Get the Big Earthquake from Harbor Freight. Has lots of torque to take the rear axle nuts off.
JOEPROPER |
Feb 14 2018, 07:41 PM
The answer is "no" unless you ask... Group: Members Posts: 1,192 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
If you can find an Ingersoll Rand IR2131, I would recommend that. Good power and reliable. I used it for many years without fail as a tech. It's heavier than many modern impact guns, but I prefer it to my modern Snap-On and my battery operated impact guns. Price is right too. Older model,but gets the job done.
porschetub |
Feb 14 2018, 07:44 PM
Advanced Member Group: Members Posts: 4,761 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hey all, had a run-in with a pretty stubborn set of axle nuts (F150 with 200k miles) the other day, and ended up shearing 4 breaker bars! (varying lengths and "quality" of bars). Ultimately ended up having to put a pipe wrench my dad has (HUGE wrench from his gas line inspecting days with Valero) and a cheater bar. I'm a huge advocate of "use the right tool for the job" though, so I'm curious if any of you guys can make recommendations for a "holy grail" impact gun that won't flinch at anything car related. My nice to haves: - $200-$400 range preferred - Electric (battery) or Air (preferred) - assume a really good air compressor/tank to drive it - Break loose anything I could encounter on a vehicle - Re-torquing lower priority as that will be by hand and/or torque wrench anyway Spent couple days researching stuff and Ingersoll Rand seems to get very good reviews. Can anyone recommend something meeting the above preferences? Electric (battery) stuff will on the edge of the hi-torque stuff need to spend $$$ to get there,air gear will kill it but you need a big compressor to feed them and you have airlines to drag around. I have a cheap battery impact and have given it death and it still go's but is limited to 90ft/pounds,its truly a great tool for what it is. End of the day your money,ok. |
iankarr |
Feb 14 2018, 07:50 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,528 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
+1 for HF Earthquake. It's a beast. You don't need an insane compressor to run it for light duty, either. A decent 25 gal unit will get the job done. Or at least it did for me. Don't forget that you'll need impact-strength sockets as well.
somd914 |
Feb 14 2018, 07:57 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Replaced my Harbor Freight of unrealistic torque values with an Ingersol Rand a few years back (sorry, don't have the part # handy). It's been well used and great, though I have run into some issues getting flywheel bolts off my Suby, yet it never fails on axle nuts and others that are torqued higher.
My son has a battery Dewalt which he bought for wheel changes and emergency work at the track. It has become very handy for wheel removal and general use in the garage as we don't have to run a hose. The downside as I've found with all my battery tools is battery replacement - generally costs more to buy a single battery than buy a new tool with two batteries - planned obsolescence. |
MarkV |
Feb 14 2018, 09:22 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
If I didn't already have air and an old Snap-on 1/2" impact I think I would buy one of these:
https://www.youtube.com/watch?v=UkPzjV-ZaTU This guy takes tools apart and tests them. |
cary |
Feb 14 2018, 09:47 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
If your working on trucks you want 1200 lb. breakaway torque.
I have a 700# IR that works on most Porsche stuff. But I borrow a 900# every once in while. We had a guy with a 1200# Snap On for the tough ones. He moved to Seattle. I'm thinking I'll get a 1200# EarthQuake too ............ |
mepstein |
Feb 14 2018, 09:53 PM
914-6 GT in waiting Group: Members Posts: 19,679 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have a cheap one for home use but the snap on's at the shop never fail me.
914_teener |
Feb 14 2018, 10:18 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Get the Big Earthquake from Harbor Freight. Has lots of torque to take the rear axle nuts off. I (IMG:style_emoticons/default/agree.gif) |
Tbrown4x4 |
Feb 15 2018, 03:56 AM
Senior Member Group: Members Posts: 707 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Happy with my Ingersoll. Used professionally and at home (30 gallon, 5HP compressor). Don't remember the model number.
mgp4591 |
Feb 15 2018, 04:08 AM
914 Guru Group: Members Posts: 5,518 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Snap-On and IRs are great guns - I've had a couple of each and they worked fine but were generally noisy. My last gun was a clutch style, an AirCat. Quiet and strong....
You didn't mention if you had a compressor or what size it might be or if you were looking at an electric but all of the ones that have been mentioned are good - just depends on what your frequency of use is and what you're using it on. |
NeunEinVier |
Feb 15 2018, 11:05 AM
Member Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None |
Another vote for Ingersoll Rand IR2131 (looks same as mine anyway), 20 years of use and mine has never let me down.
mgphoto |
Feb 15 2018, 12:11 PM
"If there is a mistake it will find me" Group: Members Posts: 1,366 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
howlndog |
Feb 15 2018, 03:45 PM
Newbie Group: Members Posts: 19 Joined: 8-February 11 From: Winnipeg, Manitoba Member No.: 12,680 Region Association: Canada |
+1 on an Aircat. The 1150 (twin hammer) or 1250 (twin clutch) are beasts. Both are inexpensive and relatively quiet.
Aircat 1/2" Impact Wrenches |
914forme |
Feb 15 2018, 03:51 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
If you can find one, the Milwaukee M18 1/2" High Torque will either take the lug nuts off, or it will shear the studs off. Up to 1100 Ft-lbs of removal torque, up to 700 fastening torque. It is a great unit.
Drums66 |
Feb 15 2018, 07:54 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....Ingersoll,snap-on,matco.......
(IMG:style_emoticons/default/bye1.gif) |
914four |
Feb 18 2018, 10:44 AM
Senior Member Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States |
I don’t have a large compressor with air tools so recently purchased the Dewalt DCF899 (1200 ft-lbs. break away). I have other tools with the same battery and I like the ability to have the same battery work on several tools. The battery is also backward compatible with older model Dewalt tools.
I used it on my parts car (a rusty Ohio car) to remove the axle nuts that have been frozen for years. I had already used my largest ratchet with cheater a bar but gave up before I broke something. That’s when I got the DCF899 which made removing the axle nuts easy. |
Ed_Turbo |
Feb 18 2018, 09:05 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
I use Mac Tools AWP 050 Titanium Impact (IMG:style_emoticons/default/sunglasses.gif) Works good for the weekend guy.
There should be a tool talk chat where folks can put reviews on any new tools they buy for garage use. |
Lo-Fi Version | Time is now: 4th January 2025 - 11:27 PM |
