JFG |
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None ![]() |
Can someone advise where to fit the trim on the decklid grills?
I have replacement from 914 rubber but dont know where it fits. Or whether it fits the grills before fitting to the decklid or after. |
JFG |
JFG |
JFG |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
welting in-between grilles and engine lid (painted part) edging on the edge of the engine lid back bottom and two sides
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The welting has the J hook to go under the edge of the metal. The sides are a little more tricky as you will have to trim a little. On the side that is not secured down directly I use a dab of contact cement to secure. I also cut the notch from the bottom of the welting to relive the pin areas.
Hope this helps, And thanks for your business, Mark Attached image(s) ![]() |
Mikey914 |
Also the protector will slide onto the bottom lip once the grill is assembled. While the factory didn't do the sides I included the material to do them as it looked like it was missing
JFG |
Superb advice thanks both.
Now i ineed to stop the trunk crushing up against the side piece grill edge. |
Mikey914 |
Is this what you need?
https://shop.914rubber.com/Rubber-bumper-to...m?categoryId=-1 Sorry the metal is not included just the bumper Attached thumbnail(s) ![]() |
JFG |
JFG |
JFG |
Don't know why it's showing sideways (IMG:style_emoticons/default/confused24.gif)
Mikey914 |
As the website is not as easy to search
13 https://shop.914rubber.com/Rubber-hood-bump...m?categoryId=-1 14 https://shop.914rubber.com/Engine-Deck-Lid-...m?categoryId=-1 12 I need to identify. we have the speednuts and washers, think it's a washer we have Attached thumbnail(s) ![]() ![]() |
JFG |
Is this what you need? https://shop.914rubber.com/Rubber-bumper-to...m?categoryId=-1 Sorry the metal is not included just the bumper I assume there are 2 of these fitted. Can someone put up a picture of where they're in the trunk hinge area? |
Mikey914 |
Is this what you need? https://shop.914rubber.com/Rubber-bumper-to...m?categoryId=-1 Sorry the metal is not included just the bumper I assume there are 2 of these fitted. Can someone put up a picture of where they're in the trunk hinge area? Picture from the website not the best, but I think you get the idea, they go in the "C" shape on the hinge bracket. Attached thumbnail(s) ![]() |
JFG |
That's the engine decklid hinges. I am referring to the bracket to stop the trunk hinges hitting the small grill sections above the battery and nearly above the relay board.
JFG |
Lo-Fi Version | Time is now: 25th June 2024 - 07:37 PM |
