rocker cover panels |
JFG |
Apr 20 2018, 02:51 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I started to refurb mine tonight. The picture below shows the only 2 fittings that i have with them.
As i lost the tear down pictures i don't have a source of info to refit them and what is used. Does any of the usual suppliers make a fitting kit for these? How do they attach in between the screws shown? Finally are these covers meant to have a slight turn/twist in them towards the rear? |
sholman5 |
Apr 20 2018, 04:07 PM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
The rubber acts as a spacer between the cover at both ends and fender and quarter panel lower lip. Remove the rubber spacer from the screw. Place spacer between the cover and fender and quarter panel lower lip. Insert screw in hole located in lip.
sholman5 |
Apr 20 2018, 04:17 PM
sholman5 |
Apr 20 2018, 04:31 PM
jcd914 |
Apr 20 2018, 05:31 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
It seems to me 914rubber had a kit with the rubber spacers.
Jim |
mepstein |
Apr 20 2018, 05:51 PM
914-6 GT in waiting Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Fuel hose will do in a pinch. Also, plastic or aluminum rivets are easier to drill out to inspect the rockers. I’m told that’s why the factory used plastic. Cut them off with a knife. 914rubber has them.
rgalla9146 |
Apr 20 2018, 07:35 PM
Advanced Member Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The hardware shown is correct for the ends. Not shown is a clip that attaches to each end of the rocker cover that the screw threads into. There is no curve toward the rear. |
porschetub |
Apr 20 2018, 08:26 PM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I put spacers under the lower mounting bolts, hard to get in but leaves a gap for the road grime to fall out,use luded stainless bolts to stop stripping out the body inserts.
JFG |
Apr 20 2018, 11:32 PM
Thanks for the info. I'll get on to mark for fittings. If i'm not mistaken the plastic/aluminium rivets may be the same as the ones for the covers on the step just above these covers.
saigon71 |
Apr 22 2018, 05:28 AM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I used small stainless steel screws to attach my rocker panel covers in the door jamb. Makes it easy to remove and inspect periodically. Just throwing it out there as another option.
Big Len |
Apr 22 2018, 05:35 AM
Senior Member Group: Members Posts: 1,748 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
I used small stainless steel screws to attach my rocker panel covers in the door jamb. Makes it easy to remove and inspect periodically. Just throwing it out there as another option. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 10:43 PM |
