cal914 |
Member ![]() ![]() Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None ![]() |
I have a 6 engine that has been uprated to 2.2 with E cams,the temp gauge keeps edging the red part of the gauge ,I e been told by the guy who rebuilt the engine that I probably need another oil cooler,can you only have these fitted in the front boot space or are there other places in the engine bay that they can be fitted
Hope this makes sense Thanks Brian |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
A couple guys have sucessfull fitted one at the trans under the car.
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,442 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
I plan on fitting one in the transmission area...with thermostatic fans.
I'll mount it and run aeroquip lines, see how it works and either go with higher quality lines (if it cools well) or go full front mount (if it doesn't cool well enough). My car will be a street car. Heck Henry at Supertec even mounted one in the engine lid and it worked just fine for the 2.7 it was on. This was on an original 914/6 chassis so the owner didn't want to cut any holes. See this thread, lots of cool ideas: http://www.914world.com/bbs2/index.php?showtopic=297973 |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
I have a 6 engine that has been uprated to 2.2 with E cams,the temp gauge keeps edging the red part of the gauge ,I e been told by the guy who rebuilt the engine that I probably need another oil cooler,can you only have these fitted in the front boot space or are there other places in the engine bay that they can be fitted Hope this makes sense Thanks Brian Under what conditions are you seeing such temps ? A 2.2 E should not need a front cooler. I'd get a second opinion. Determine that your gauge is correct and the engine is healthy |
Boomingbeetle |
Member ![]() ![]() Group: Members Posts: 118 Joined: 1-November 16 From: Orange County Member No.: 20,556 Region Association: Southern California ![]() |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,263 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
Lots of experience here on the board and I have worked at it too.
My experience with a 2.4 S motor is that under every day driving that you should find temps manageable without a second cooler. Long highway cruising and getting into it hard for sustained romps seem to be the most problem times. Even then you should be able to stay under 210 even on hot days. I made sure that my shroud was well sealed especially around the oil cooler and I also have the modified baffles. I highly recommend that you check your timing. I think that retarding a few degrees off of the recommended max advance and running around 28 - 30 degrees makes a huge difference without materially effecting performance (especially with higher compression than stock). Lean mixtures can also contribute to hot running. I do believe that the rear mounted coolers do help. I built one with extensive ducting and a thermostat control that kept me cool even at the track on fairly hot days. One problem is with over pressuring these coolers with cold oil. Having a warm up bypass is necessary if you want to run in the winter. I think your options are 1) Check your systems carefully - make sure you are not running lean and that timing is "conservative" and that your cooling system (fan and shroud) is working well WITH NO AIR LEAKS. 2) If #1 helps, live with it. 3) If still marginal, try the under trunk cooler with a fan. I think it is worth about 15 degrees. Good luck. |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
I think any additional cooler capacity should help, but I also wonder why you need one as a friend has a strong, modified 2.4 in his 911 and has driven coast to coast with no overheating issues. I’d also check your timing before spending money or see if there’s any other reason for the overheating first.
If you do decide on a cooler, Ben (mb911) has now reproduced beautiful 914GT oil lines to run to the front of the car to install a ducted front cooler. |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Brian, a 2.2 should not need a remote oil cooler. We have successfully run sixes with as large as 2.4 without another oil cooler. 2.7 and up definately need one when installed in a six.
The problem with installing an oil cooler is that it cuts up the original car a bit, the best place to install where the factory did in the front trunk against the front panel. we have three factory cars here with that arrangement, all have 2.4 or larger engines The ones installed under the trunk floor by the side of the transmission are not very effective as they are right in the midst of the hot exhaust and engine and transmission. If installed they all need an additional fan, more rig up for an original six I would suspect that there is something wrong with the installation to run that hot I have a 6 engine that has been uprated to 2.2 with E cams,the temp gauge keeps edging the red part of the gauge ,I e been told by the guy who rebuilt the engine that I probably need another oil cooler,can you only have these fitted in the front boot space or are there other places in the engine bay that they can be fitted Hope this makes sense Thanks Brian |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I have a 1.7 Reno car that has an external cooler. So far all indications are it works well. If you live somewhere hot, high, or spend time sitting still on the freeway, the aditional cooling and capacity are an adition margin of safety, as well as having an aditional filter.
cal914 |
This is where the temp gauge was yesterday with out side temp at 28 degrees (82 F),the motor has less than 1500 miles on a complete rebuild ,at the time of the pic being taken I had been sitting in traffic for about 10 mins ,before that the gauge was steady at about 5mm from the red
Is the temp to high for this engine ![]() Attached thumbnail(s) ![]() |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Another item to consider is oil temp sender and gauge mis match, that will cause them to read differently.
Found it (IMG:style_emoticons/default/piratenanner.gif) ![]() |
rgalla9146 |
Another item to consider is oil temp sender and gauge mis match, that will cause them to read differently. Found it (IMG:style_emoticons/default/piratenanner.gif) ![]() (IMG:style_emoticons/default/agree.gif) Now we're talking. |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Others already said may be a mis-match guage-to-sender. You should not need
another cooler if things are working properly. I have nearly the same motor. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Under what conditions are you seeing such temps ? A 2.2 E should not need a front cooler. I'd get a second opinion. Determine that your gauge is correct and the engine is healthy (IMG:style_emoticons/default/agree.gif) |
cal914 |
Another item to consider is oil temp sender and gauge mis match, that will cause them to read differently. Found it (IMG:style_emoticons/default/piratenanner.gif) ![]() The part number on my gauge is 914-641-101-10 that number doesn’t appear on the chart above ,the temperature sender is from my friends 6 are these 2 things compatiable or could this be the problem Attached thumbnail(s) ![]() |
mskala |
Part number is close, should be equivalent, but this is what I have.
![]() You can pull the sensor and check its part number, and/or just order the correct new one. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
You should be running a 150C sender (300F) I would be inclined to replace it ,if you get no improvement take the gauge and sender to a auto electrician and have it checked/calibrated.
If the above is done you need then proceed with the following; Check timing isn't over advanced, Make sure the carbs aren't jetted lean, Is the fan belt tight, Is the air deflector on the back of the altenator in the correct position, All spark plug seals and engine tin seals in place, Is the thermostat operating correctly, Has the heater system got the correct heater valves. Do you have the correct valve clearances. One or more of the above things can amount to your overheating,I would start with the timing and carbs first,you look to be running it the 120C+ range which rather hot...not something that is good for your engine. |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
My 2.4 S spec /6 HAS a front oil cooler; the needle hardly ever budges.
Just saying..... (IMG:style_emoticons/default/bye1.gif) |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
GeorgeRud |
Those surely look beautiful! Another thought is to check the sender in boiling water to see where it reads on the gaug.
Lo-Fi Version | Time is now: 26th June 2024 - 08:05 AM |
