Aligning cone screws on shift rod |
PanelBilly |
May 9 2018, 06:27 PM
914 Guru Group: Members Posts: 5,840 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
With the installation of my new heat exchangers on the 3.0, I can't align the cone screws so they line up with the holes in the rod. I'm thinking I just need to drill new holes. Anyone else have this issue?
GeorgeRud |
May 9 2018, 07:02 PM
What linkage are you running? Aren’t there splines that can be readjusted to line things up?
falcor75 |
May 9 2018, 11:23 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Is it the HE's or the 3.0 that are new? The six needs a different shift rod than a four.
porschetub |
May 10 2018, 12:25 AM
Advanced Member Group: Members Posts: 4,725 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I ditched my 911 style coupler for a uni joint because it has a 2way action did the same @ the rear as per what some venders supply but that can only be used with a dual console bushing for best result.
Replacing the conventional firewall coupler is a step ahead with one of TR's bulkhead bushes expect you already know that by now. |
Lo-Fi Version | Time is now: 28th September 2024 - 05:00 PM |
