Electric Windshield Washer Conversion 914, Complete kit |
rothaus |
Jul 15 2018, 01:20 PM
Member Group: Members Posts: 119 Joined: 20-November 10 From: Virginia Member No.: 12,404 Region Association: None |
On the Porsche 914 the original windshield washer is operated by compressed air supplied from the Spare tire.
Here is the switch that replaces the original valve in the steering column. With this switch installed, an electrical washer pump can be operated with the wiper switch. (IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1531682421.1.jpg) I got some requests if it would be possible to have a complete kit available. So I put together a complete kit, and also have now options. It's not yet on the website, however here is the information with the options and prices. Option 1: Switch only - $15.00 PLUS $5 s/h Option 2: Relay kit only - $35.00 plus $6 s/h Option 3: Switch and relay kit - $50.00 plus $6 s/h Option 4: Option 3 plus pump - $72.00 plus $8 s/h The switch is pre-wired and includes the mounting plate and some washer for adjustment if needed. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-12404-1623100568.1.jpg) The relay kit includes all wires, a fuse, and connectors, shrink tubing, bolt to mount the relay, as well the disc for the filler cap. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-12404-1623100568.2.jpg) Here is the wire diagram which will also be included in the step by step instructions. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg) The switch can be ordered at http://carmagic.us/washer.html Cheers Engelbert |
orthobiz |
Jul 19 2018, 04:24 AM
Senior Member Group: Members Posts: 1,757 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I did this conversion in the 80's on an old car of mine with Radio Shack parts. I wish this thing was available at the time, way more elegant and a good value. Betcha some would like the motor and tubing as a complete bundle...
Paul |
bretth |
Jul 19 2018, 06:20 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Awesome! Beats having windshield fluid dripping in your lap.
Brett |
amfab |
Sep 13 2018, 08:38 PM
Member Group: Members Posts: 401 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
well thats just a fantastically simple solution. Will buy one when I get to reassembly
cary |
Sep 15 2018, 09:21 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
That's cool ............. Well done.
I think I'll inventory a few for future projects. |
BillC |
Oct 23 2018, 04:25 PM
Senior Member Group: Members Posts: 557 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
I installed one of these in my 914 a couple of weeks ago. Very straightforward installation, and basically went as well as you could expect.
A couple of minor points, though:
buck toenges |
Feb 7 2019, 03:19 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
Can somebody help me with the electrical hook up? I have 2 wires from the switch and I have 2 wires from the pump. How do I hook those wires up and get power to the pump?
Thanks, Buck |
rothaus |
Feb 7 2019, 07:11 PM
Here is a video from A electric washer pump conversion. This may help. The only difference is that there will be no switch to be installed in the dash, and the lever can be used to operation the electric pump.
Video |
davep |
Feb 8 2019, 10:45 PM
914 Historian Group: Benefactors Posts: 5,213 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The wiring is very simple. From a fused 12 volt source (fuse panel) run a hot wire to the pump positive side. From the pump negative side run a wire to the switch. From the other side of the switch run a ground wire to the multiple ground stud near the fuse box. I am not sure what the switch rating is, so a relay could be added to keep the switch current in line with it's rating. I came up with a mounted switch years ago to do this very task.
http://www.914world.com/bbs2/index.php?sho...7916&st=29# |
rothaus |
Feb 10 2019, 05:04 PM
Ok, here is my recommended wire diagram for the washer switch installation. However, there are other ways to wire the switch.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg) Hope this will help. Thanks Engelbert |
cary |
Jan 25 2020, 12:18 AM
Bump
russmoffat |
Feb 28 2020, 08:34 PM
Newbie Group: Members Posts: 11 Joined: 17-May 16 From: Valencia, CA Member No.: 20,002 Region Association: Southern California |
I did this exact setup here. Wondering if anyone else has had issue with the switch going off unintentionally? Seems like it is too sensitive and has gone off a few times for me when I didn’t want it to. Considering inserting a spring to ensure that it stays put unless you put pressure on it?
Mikey914 |
Feb 29 2020, 08:27 PM
The rubber man Group: Members Posts: 12,736 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I did this conversion in the 80's on an old car of mine with Radio Shack parts. I wish this thing was available at the time, way more elegant and a good value. Betcha some would like the motor and tubing as a complete bundle... Paul I can supply tubing if you need it. |
FUEL14 |
Sep 9 2020, 06:06 PM
Member Group: Members Posts: 56 Joined: 11-August 18 From: Melbourne, Australia Member No.: 22,382 Region Association: Australia and New Zealand |
If I want to use the column stalk for the washer, can Engelbert's switch be used in conjunction with SirAndy's method as described here http://www.914world.com/specs/tech_el_washer.php ?
FlacaProductions |
Sep 11 2020, 09:12 AM
Senior Member Group: Members Posts: 1,809 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
@FUEL14 - yes. I did just that. Just use the new column switch for step 8 in Andy's method.
FUEL14 |
Sep 11 2020, 06:07 PM
Fantastic, thanks for confirming. |
ThinAir |
Oct 21 2020, 02:31 PM
Best friends Group: Members Posts: 2,553 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Where has this been all my life? Ordered!!!!!
DRPHIL914 |
Apr 25 2021, 04:53 PM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Ok, here is my recommended wire diagram for the washer switch installation. However, there are other ways to wire the switch. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg) Hope this will help. Thanks Engelbert since several other members are dealing with this issue again , i am bringing it up again to ask if this relay will work? only difference i see is it has a 87 & 87b. that and the 85&86 are unopposed positions. Attached thumbnail(s) |
Zaffer |
Apr 25 2021, 08:10 PM
Member Group: Members Posts: 98 Joined: 10-December 06 From: Radiant, VA Member No.: 7,343 Region Association: MidAtlantic Region |
Will definitely order soon as I expect to have the car (possibly) back on the road this year.
cary |
Apr 25 2021, 08:20 PM
We've installed a couple without any issues in the shop.
I'll have to ask the clients. |
Lo-Fi Version | Time is now: 28th November 2024 - 11:34 AM |
