76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I haven't seen any black ones. Just off white ones. (IMG:style_emoticons/default/WTF.gif)
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
makes no difference, when you peel off the covering the black sticky is under it
Minerva's 914 |
Member ![]() ![]() Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States ![]() ![]() |
we have at least 20 of the correct factory ones on the shelf
saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Rearview mirror fell off in my hand today. (IMG:style_emoticons/default/dry.gif) I just ordered the rearview mirror pad from Sierra Madre.
Question - is this pad alone enough to keep the mirror attached or do I need to pick up some rearview mirror adhesive as well? Thanks. |
carking1996 |
Member ![]() ![]() Group: Members Posts: 69 Joined: 15-September 16 From: Ohio Member No.: 20,399 Region Association: North East States ![]() |
I too have this question
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Rearview mirror fell off in my hand today. (IMG:style_emoticons/default/dry.gif) I just ordered the rearview mirror pad from Sierra Madre. Question - is this pad alone enough to keep the mirror attached or do I need to pick up some rearview mirror adhesive as well? Thanks. If you read George’s book he points out that a bit of silicone sealant around the edges keeps air from coming betwixt pad and windshield. |
DdHavtech |
Newbie ![]() Group: Members Posts: 7 Joined: 21-March 18 From: Ellicott City, MD Member No.: 21,993 Region Association: None ![]() |
Rearview mirror fell off in my hand today. <_< I just ordered the rearview mirror pad from Sierra Madre. Question - is this pad alone enough to keep the mirror attached or do I need to pick up some rearview mirror adhesive as well? Thanks. If you read George’s book he points out that a bit of silicone sealant around the edges keeps air from coming betwixt pad and windshield. My problem is the mirror base does not stick to the sticky pads. Anybody else have this issue? |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I've used windshield mirror epoxy. Any glass shop has premixed little epoxy cups made specifically for this application. Get it right the 1st time, but sets up fast and will hold. They run about $3.
yes have seen it all of the time, especially if one at one time glued the mirror directly to the windshield. The pad also helps dampen vibration so certainly use it. You may have to scrape the base clean of the shiny glue. The base is not shiny what so ever so if yours is, it has mirror glue on it. Also lacquer thinner will help clean the base followed by soap and water to get the residue off. THEN the patch will stick well and you will be on your way
Rearview mirror fell off in my hand today. (IMG:style_emoticons/default/dry.gif) I just ordered the rearview mirror pad from Sierra Madre. Question - is this pad alone enough to keep the mirror attached or do I need to pick up some rearview mirror adhesive as well? Thanks. If you read George’s book he points out that a bit of silicone sealant around the edges keeps air from coming betwixt pad and windshield. My problem is the mirror base does not stick to the sticky pads. Anybody else have this issue? |
davesprinkle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None ![]() ![]() |
Rearview mirror fell off in my hand today. (IMG:style_emoticons/default/dry.gif) I just ordered the rearview mirror pad from Sierra Madre. Question - is this pad alone enough to keep the mirror attached or do I need to pick up some rearview mirror adhesive as well? Thanks. If you read George’s book he points out that a bit of silicone sealant around the edges keeps air from coming betwixt pad and windshield. Silicone has no place anywhere on any car. |
Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
Rearview mirror fell off in my hand today. (IMG:style_emoticons/default/dry.gif) I just ordered the rearview mirror pad from Sierra Madre. Question - is this pad alone enough to keep the mirror attached or do I need to pick up some rearview mirror adhesive as well? Thanks. If you read George’s book he points out that a bit of silicone sealant around the edges keeps air from coming betwixt pad and windshield. Silicone has no place anywhere on any car. You’ve obviously missed a few key pictures in the “hot chicks” thread in the sandbox. |
saigon71 |
I appreciate all the info, but I still don't know if a fresh mounting pad will hold it by itself or if I need to use the rearview mirror adhesive in addition to the new mounting pad.
Thanks. |
Cal |
Senior Member ![]() ![]() ![]() Group: Members Posts: 615 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States ![]() |
I recently reinstalled my interior mirror with the Permatex adhesive product that's sold at autozone and it worked great....no issues. The base unscrews from the mirror so it makes installing it easier. Just follow the instructions on the Permatex package....I used painters tape to help hold the base in place while the glue set for 24 hours.
Attached thumbnail(s) ![]() Attached image(s) ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Used 944 one from Pelican ,stuck really well ,no issues so far,cleaned up mirror and windscreen with acetone after using sharp blade on windscreen and mirror base.
Personally never hand any luck with adhesive. |
DdHavtech |
Is the base of the mirror supposed to have (or be) metal that goes to the windshield? I saw the picture posted by Cal and it looks like metal. When I got the car the mirror was in the glovebox.
Only the edges of the base are metal and the rest of the inside is like a dampening material and the pads don't stick to it. Maybe that is the issue? The rest of the 40k mile car runs great. Thanks guys. |
76-914 |
I recently reinstalled my interior mirror with the Permatex adhesive product that's sold at autozone and it worked great....no issues. The base unscrews from the mirror so it makes installing it easier. Just follow the instructions on the Permatex package....I used painters tape to help hold the base in place while the glue set for 24 hours. I used that product on my 76 9 years ago and it is still in place however I was left looking at the shiny metal where it mates to the windshield. It drives me nuts every time I walk past that car. Maybe I could have used a black Marks-a-lot before applying the glue? (IMG:style_emoticons/default/confused24.gif) I'll change it when I redo that car in the next year or two. When I stand in front of the car I want this one to look black or dark grey where it attaches. (IMG:style_emoticons/default/beerchug.gif) |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Is the base of the mirror supposed to have (or be) metal that goes to the windshield? I saw the picture posted by Cal and it looks like metal. When I got the car the mirror was in the glovebox. Only the edges of the base are metal and the rest of the inside is like a dampening material and the pads don't stick to it. Maybe that is the issue? The rest of the 40k mile car runs great. Thanks guys. Can you post a pic? |
DdHavtech |
Is the base of the mirror supposed to have (or be) metal that goes to the windshield? I saw the picture posted by Cal and it looks like metal. When I got the car the mirror was in the glovebox. Only the edges of the base are metal and the rest of the inside is like a dampening material and the pads don't stick to it. Maybe that is the issue? The rest of the 40k mile car runs great. Thanks guys. Can you post a pic? ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 06:36 AM |
