milwlandrover |
Member ![]() ![]() Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest ![]() |
So I have a lot of things sorted in my (new to me) 1971 but I found that at about 55mph I have a dip in power and when I let off the throttle I get a back fire. I saw somewhere on the post that this is generally means it is running rich or could be an exhaust leak. The car is fuel injected so how do you adjust the fuel/air? I've never been a mechanic but the am learning with all your help.
Cheers! |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Look for air leaks. all the little vacuum tubes need to be tight and not leaking. Make sure you are running correct fuel pressure. And make sure your exhaust is not leaking.
Zach |
milwlandrover |
Thanks Zach
Lo-Fi Version | Time is now: 25th June 2024 - 06:20 PM |
