Alapone |
Member ![]() ![]() Group: Members Posts: 106 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None ![]() |
Does anyone have a measurement for the distance between the two rear suspension console ears/pickup points?
Im looking for the spot where the trailing arms attach to the chassis, the distance between. Should be easy enough but I cant seem to locate it here. Thanks Andrew |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
BPic |
Member ![]() ![]() Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States ![]() ![]() |
Inside to inside I have 33 1/4"
David Billo |
Member ![]() ![]() Group: Members Posts: 64 Joined: 23-November 17 From: Plainfield, Ontario Member No.: 21,625 Region Association: Canada ![]() |
I've forgotten where I got this, but pretty sure it was somewhere on this forum.
Attached image(s) ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
One of these days I’ll successfully convince Ben to make a jig. If it also mounted the front suspension mounting points, it would be an easy way to test the chassis. alignment.
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
I've forgotten where I got this, but pretty sure it was somewhere on this forum. From here: http://www.914world.com/bbs2/index.php?s=&...t&p=1009428 Had that diagram taped to the side of my chassis for a few months. |
Alapone |
Thanks guys I appreciate it. I will take a measurement tonight.
Lo-Fi Version | Time is now: 25th June 2024 - 07:04 PM |
