Fiberglass floor panels?, Recently bought a 914 and when I searched for rust on the floor I found fiberglass |
Mendivil26 |
Sep 4 2018, 12:34 PM
Newbie Group: Members Posts: 31 Joined: 26-July 18 From: Riverside, Ca. Member No.: 22,344 Region Association: Southern California |
Hi, first time poster, since I just got my 75' 914-4 2.0 a month ago.
Car runs and drives, but is cosmetically ugly, it was originally copper, but one of the previous owners painted over the copper to make it look green, now the green paint is falling off. ANYWAY! My intention is to drive it around with spartan interiors, just the essentials, no carpets and barely any electronics to keep it simple and fewer things that can go wrong since my goal is reliability (yes, it's a daily driver). So this past weekend I started gutting the interior and removing all the carpets, expecting to find metal panels that I would look closely at for rust damage and evaluate if I they were going to need to get replaced or repaired or what.. to my surprise, I did not find metal, I found what I believe is fiberglass or some type of cardboard panel covered in resin. It looks like one of the previous owners laid up fiberglass over the metal panels, either to protect them from rust, or to cover all the rust spots that were already there. I tried searching for info on this already to no avail, looks like it's not common practice. Has anyone else seen this done before? Should I be worried? what would you recommend as a path forward? |
TravisNeff |
Sep 4 2018, 12:38 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
That is tar sheets over the sheet metal floors. that is from the factory, and your floors look good!
tygaboy |
Sep 4 2018, 12:41 PM
914 Guru Group: Members Posts: 5,454 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
That looks like the factory "tar" coating. You can scrape it off (heat guns help) to check for rust underneath.
Lots of posts about this... |
SirAndy |
Sep 4 2018, 12:55 PM
Resident German Group: Admin Posts: 41,897 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
That is tar sheets over the sheet metal floors. that is from the factory (IMG:style_emoticons/default/agree.gif) Sound proofing tar sheets, applied at the factory. They can crack and let water through, especially near the rear firewall which results in rust under the tar. Do a search here, there's plenty of threads on the subject ... (IMG:style_emoticons/default/bye1.gif) PS: (IMG:style_emoticons/default/welcome.png) |
Mendivil26 |
Sep 4 2018, 01:39 PM
Thanks for the quick respone guys!
Now I feel dumb because I knew about the tar sheets, I just didn't know what they looked like. What made me think it was fiberglass was because of what I also found in the rear trunk: I'm pretty sure that IS fiberglass on top of rust, or is it some other kind of obvious sound deadening that I didn't know was supposed to be there? |
SirAndy |
Sep 4 2018, 01:55 PM
I'm pretty sure that IS fiberglass on top of rust Yep, that would be some DAPO's "fix" for a rusted trunk floor ... (IMG:style_emoticons/default/icon8.gif) |
Mendivil26 |
Sep 4 2018, 02:04 PM
DAPO's??
jcambo7 |
Sep 4 2018, 02:06 PM
Senior Member Group: Members Posts: 1,691 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
914 Ranch |
Sep 5 2018, 12:00 AM
Team Sharp where the 914 grow wings Group: Members Posts: 1,462 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
Fiberglass bonds to the rust but dose not stop the rust, eventualy it will delaminate. As you can see in the trunk. Once I thought I had a rust free driver, went over a bump and the battery tray fell. DAPO, sheet metal screws don't work in fiberglass. Hole floor and half of the fire wall and passenger inner fender well was done. Driver seat rails were coming out the bottom of the floors when I cut the car up.
DRPHIL914 |
Sep 5 2018, 09:52 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
what color is your car? it looks like Copper Metallic(L99K)!
Jonathan Livesay |
Sep 5 2018, 10:31 AM
Senior Member Group: Members Posts: 744 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
If it is Copper and Green just call it The Bad Penny and (IMG:style_emoticons/default/driving.gif) it.
Mikey914 |
Sep 6 2018, 07:35 AM
The rubber man Group: Members Posts: 12,736 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
draganc |
Sep 7 2018, 09:07 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Interesting approach with the dry ice and IPA.
I cleaned/removed both sides in less than 30min with a oscillating multi tool and scraper blade (see Link). The clean up was extremely easy and dry. https://m.harborfreight.com/multi-tool-blad...3-pc-61827.html |
Lo-Fi Version | Time is now: 27th November 2024 - 12:50 PM |
