heater blower, heater lever wire starts smoking |
slotty008 |
Oct 21 2018, 06:20 AM
Member Group: Members Posts: 192 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
A couple of weeks ago ,on a cold morning and driving a rally, I pulled the console heater lever to get some heat in the cockpit( never used it before). Nada! So I tried to figure out where the problem came from. Started with the blower motor : it didn't run. So I took it apart, cleaned it out, greased it and it runs freely now when I put 12V on it. But it didn't work in the car. So I checked the engine bay relay box. The heater blower relay was missing, so I ordered a new one. Still nothing. I took out the heater lever and checked the green-white wire. It looked OK to me , but as soon as I make contact with the ground , it starts smoking at the end. So there must be a short circuit somewhere.
I don't intend to take out the whole wiring harness so what can I do to fix it or where do I start looking? |
rhodyguy |
Oct 21 2018, 07:04 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,193 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Until you sort the electrical issue out, Disconnect the fan power and cap the J tubes with rubber pipe caps from the hardware store. You'll have PLENTY of heat if the HEs are in good shape. The engine fan pressure overcomes the the aux fan pressure as engine speed increases and closes the 2 little doors on the fan shroud.
Olympic 914 |
Oct 21 2018, 09:46 AM
Group: Members Posts: 1,709 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
The engine fan pressure overcomes the aux fan pressure as engine speed increases and closes the 2 little doors on the fan shroud. (IMG:style_emoticons/default/WTF.gif) Wouldn't it open the little doors? I really never knew what the little doors were for anyways but I left them in. |
slotty008 |
Oct 21 2018, 10:41 AM
Until you sort the electrical issue out, Disconnect the fan power and cap the J tubes with rubber pipe caps from the hardware store. You'll have PLENTY of heat if the HEs are in good shape. The engine fan pressure overcomes the the aux fan pressure as engine speed increases and closes the 2 little doors on the fan shroud. Thx for the reply. I think one of the HE's is losing a little bit of air. I can feel a draught when I put my hand on it.(I connected the blower motor with an external 12V supply). Next week I can put the car on a lift to check it out. But that doesn't solve my electrical problem. |
slotty008 |
Oct 21 2018, 12:09 PM
Until you sort the electrical issue out, Disconnect the fan power and cap the J tubes with rubber pipe caps from the hardware store. You'll have PLENTY of heat if the HEs are in good shape. The engine fan pressure overcomes the the aux fan pressure as engine speed increases and closes the 2 little doors on the fan shroud. Thx for the reply. I think one of the HE's is losing a little bit of air. I can feel a draught when I put my hand on it.(I connected the blower motor with an external 12V supply). Next week I can put the car on a lift to check it out. But that doesn't solve my electrical problem. I have a '75 and the fan has just one little door. |
914_teener |
Oct 21 2018, 12:10 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I had this exact problem when I first got me car.
Two main areas it could be, at least from my experience. Check the traces on your regulator plate and where the wire for the heater....essentially it just grounds the relay. In the back of the harness it has pin connectors the connects the traces to the heater lever. In my case the wire had cracked and when grounded shorted the wire heating the harness and smoking the wire. I reran this lead completely to fix it. Bottom line....check the regulator plate and the ground wire itself. T |
slotty008 |
Oct 21 2018, 12:44 PM
I had this exact problem when I first got me car. Two main areas it could be, at least from my experience. Check the traces on your regulator plate and where the wire for the heater....essentially it just grounds the relay. In the back of the harness it has pin connectors the connects the traces to the heater lever. In my case the wire had cracked and when grounded shorted the wire heating the harness and smoking the wire. I reran this lead completely to fix it. Bottom line....check the regulator plate and the ground wire itself. T OK, will try that next week and let you know. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 26th December 2024 - 05:51 PM |
