Motor swap, 2.9 (base) Cayman, pros, cons & headaches |
MotoringMan |
Nov 29 2018, 08:27 AM
Newbie Group: Members Posts: 5 Joined: 3-November 18 From: USA Member No.: 22,624 Region Association: None |
Hey Teeners,
Over the years I've owned some 911's but, have recently acquired my first 914 with little to no rust (southern car) and this led me to join 914world forum. My question is there been any Cayman motor swaps out there and threads I could read, follow and ask questions. I have access to a complete 2009 2.9 (base) Cayman motor complete with harness and ECU. Thanks, Mark |
Tdskip |
Nov 29 2018, 09:04 AM
Advanced Member Group: Members Posts: 3,703 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
First of all welcome! Good people here, glad you joined us.
Most swaps of other Porsche engines, as you likely already know, are air cooled 911 engines. You would have a lot of work to do, but those cars are very fabrication friendly. If you do go this route make sure to brace the chassis. |
Chris H. |
Nov 29 2018, 09:34 AM
Senior Member Group: Members Posts: 4,053 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I don't recall any build threads here of water cooled Porsche 6's but there has been plenty of speculation, consideration, measuring (IMG:style_emoticons/default/idea.gif) . There are also many Subaru 6 threads that could help you with coolant line plumbing, radiator selection , etc. The original verdict was that the Porsche engine was too wide. Then it was determined that the engine would fit if the /4 engine mounts were removed. You could use modified air cooled 6 firewall engine mounts that are readily available. You would want to use the Porsche 6 speed trans with it since it bolts right up as opposed to the stock 914 trans. |
yellowporky |
Nov 29 2018, 09:40 AM
Member Group: Members Posts: 429 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
I believe the issue was the trailing arm mounts are in the way not the motor mounts witch are very easy to remove. There was a build thread in Australia that had a boxster motor. If i remember correctly he pushed the motor forward and had to move the coil on plug from the rear plugs to a wire to the coils and it still seamed too tight.
you will need to change the trailing arm suspension to something else. |
Chris914n6 |
Nov 29 2018, 11:26 AM
Jackstands are my life. Group: Members Posts: 3,431 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
^^ the motor is too wide and hits the inner trailing arm mount. That is the big reason it isn't a feasible swap.
ndfrigi |
Nov 29 2018, 11:48 AM
Advanced Member Group: Members Posts: 2,960 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Rick 918-S has a 928 engine on his 914 black.
Chris H. |
Nov 29 2018, 12:14 PM
Pretty sure I heard of a couple of successful swaps. I think they used LS coils instead of the stock coil packs because the clearance was so minimal. Very tight fit. Maybe someone will remember more than me and chime in.
thelogo |
Nov 29 2018, 12:48 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Its a width clearance issue or length
Because i assume the next logical step is a 718 4 cyclinder motor . But will that have same / similar fittment issues . And when are electical assist motors going to replace turbocharging Of engines all together Push to pass instead of having all the turbo complexity ??? (IMG:style_emoticons/default/wub.gif) |
BIGKAT_83 |
Nov 29 2018, 01:46 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Running driving car with no mods to suspension mounts.
914_teener |
Nov 29 2018, 01:51 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
2.7 or 3.4?
Nice. One of my latest acquisitions. |
Chris H. |
Nov 29 2018, 01:59 PM
Yeah that's the one! Thanks Bob! Looks pretty good in there. Did they use the stock ECU or aftermarket? I remember looking into the wiring and there was an immobilizer that might be a problem.
thelogo |
Nov 29 2018, 02:09 PM
Running driving car with no mods to suspension mounts. (IMG:style_emoticons/default/lol-2.gif) Nice rain funnel bet it connects to the Coolant tank ? |
eeyore |
Nov 29 2018, 02:12 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
Does anybody have any idea what a 9A1 engine / tranny combo weighs?
BIGKAT_83 |
Nov 29 2018, 05:30 PM
Chris914n6 |
Nov 29 2018, 07:38 PM
eeyore |
Nov 29 2018, 08:50 PM
QUOTE Research says the motor loaded weighs right at 400lbs. Looks like 260kg or 572lbs with the transaxle,bet a LS/V8 would be lighter. Boo!!! What on earth did they make those things out of? |
MotoringMan |
Nov 30 2018, 07:59 AM
Looks like a nice fit. This there a thread of this build or do you have any photos and helpful advise.
Definitely use the 6M transaxle from the 9A1 but, one question is will the motor need to be moved forward or back to get the axle aligned and center of fender opening. Another concern is over all height of the motor and how much of the upper truck cross section will fabricated. 9A1 motor measures from the crank center line to the top of intake runner just 15" which leads me to believe the original type 4 with injection was much higher. Would also need custom axles made to marry the new transaxle and 914 hub. I've yet to weight the motor but rolling it around on the floor seems 350-400lbs. Running driving car with no mods to suspension mounts. |
MotoringMan |
Nov 30 2018, 08:03 AM
9A1 donor
Attached thumbnail(s) |
MotoringMan |
Nov 30 2018, 08:17 AM
1973 1.7
mepstein |
Nov 30 2018, 08:35 AM
914-6 GT in waiting Group: Members Posts: 19,702 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
1973 1.7 Pretty car. No way would I engine swap it. Find a beater 914 and play with it. I'm doing a suby swap on a chassis that the prior owner already cut out the engine shelf, half the rear trunk and installed a nasty roll cage that I had to remove. Chassis was hacked so no real loss. No way would I do that to the car you show in the pics. |
Lo-Fi Version | Time is now: 15th January 2025 - 02:22 AM |
