echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
Since I have a hole in the front trunk where the A/C condenser is I was wondering were the hole in the trunk is tha facilitates the neg pressure for the oil cooler.
Maybe I wont have to patch the whole thing. Show me whatchagot! |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
I used the pictures from the following link.
http://fly.hiwaay.net/~jonlowe/MyGT0005.html I bought my GT shroud and air deflector from Getty design. Good luck, Steve |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,711 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
i'm still not sold on that design ...
you're pushing a lot of air UNDER your car, which is the last place where you actually want that air. i've seen a few 914 racers that have the air exit through the hood, effectively adding more downforce to the nose ... later, Andy |
SirAndy |
this one's not very pretty, but it gives you an idea ...
(IMG:http://www.ultimate914.com/MOTORSPORTS_WE/photo_4/IMAG0000.JPG) |
echocanyons |
Andy,
I hadnt thought of doing it that way. How big would the hole have to be? |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
Kelly,
that is one of the smaller holes that I have seen. All the others I have seen look to be 3-4 inches wider. |
SirAndy |
yes, most of them are wider than the one in the previous pic.
the size should be at least the same (square inch) as the hole for the oil cooler, probably a bit bigger, cause hot air expands. for a street car, i have played with the idea of replicating the ferrari 328 look, a friend of mine has one, so i have a "model" to work off ... for a race car, it doesn't really matter, i guess. Attached image(s) ![]() |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Not wise on a street car. It dumps the hot air straight into the passenger compartment when the top is off and your doing your daily driving.
I agree it dumps air under the car and it could create a slight "lift" situation..but any newer air dam has a splitter in it that counters this effect. B |
SirAndy |
QUOTE(Brad Roberts @ Jul 15 2003, 08:45 AM) It dumps the hot air straight into the passenger compartment when the top is off and your doing your daily driving. for those who like it HOT (IMG:style_emoticons/default/laugh.gif) |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
The cooler on my race car exits underneath and so far I have seen no problems with the air flow. The front spoiler seems to create a pretty good negative pressure area behind it and the air from the cooler and brake ducts exits well. You have to be careful with too much front downforce since the car can become very unbalanced since there is nothing in the rear to help push down. Most front trunk cooler exhaust cars I have seen also run a rear wing to balance things. Good luck
Pnambic |
Honk if you like obscene gestures! ![]() ![]() ![]() Group: Members Posts: 914 Joined: 9-April 03 From: Atlanta, GA Member No.: 546 Region Association: South East States ![]() |
Another example of the hood air vents. Not quite as classy as the Ferrari though. With the angle of the vents, it looks like they're trying to direct the air to the sides of the windshield, but as Brad mentioned, you still have hot air coming in from the side windows.
I wonder if it helps keep the bugs off the windshield... (IMG:style_emoticons/default/confused24.gif) Attached image(s) ![]() |
Lo-Fi Version | Time is now: 30th June 2024 - 10:58 AM |
