kupcar |
Member ![]() ![]() Group: Members Posts: 95 Joined: 14-February 13 From: Chicago Member No.: 15,528 Region Association: None ![]() |
I’m looking for some ideas on adding an oil cooler to my 914-6 gt clone. The car currently has a 2.2s spec motor running without an external oil cooler. Temperature has never been an issue, but it seems like a good idea to have some extra cooling. I’m not interested in cutting up the front trunk at the moment. There doesn’t look like enough room to mount one in the front nose without doing so. What other options are available? Thanks in advance.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
There are threads on rear cooler installs.
But if your car runs at the correct temp, I wouldn't touch it. |
Racer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region ![]() |
Ive seen them mounted under the trunk, in the trunk and along the engine lid. Short of that, they are run up front for the most efficient and "authentic" location.
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
A 2.2 doesn't require extra cooling. I would be happy to help with the front cooler setup but just not required.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
not needed for a 2.2 unless racing it heavily, Only 2.7 and up need an external oil cooler, do not spend the money and or cut up your car
I’m looking for some ideas on adding an oil cooler to my 914-6 gt clone. The car currently has a 2.2s spec motor running without an external oil cooler. Temperature has never been an issue, but it seems like a good idea to have some extra cooling. I’m not interested in cutting up the front trunk at the moment. There doesn’t look like enough room to mount one in the front nose without doing so. What other options are available? Thanks in advance. |
kupcar |
I’ve seen a few rear cooler installations. Mostly for bigger type IV motors. I was wondering if it was worth the effort to plumb something into the fender. I understand that the location is far from ideal. It is amazing to me that everything stays relatively cool using solely the engine oil cooler. I even double checked my gauge for accuracy. I guess until I decide to open the nose up and do it correctly, the consensus is leave it alone. One less thing on the “to do” list! I appreciate everyone’s input.
thelogo |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None ![]() |
What is your oil compassity like 12 -15 quarts or something
I imagine that has something to do with keeping the engine cool |
mepstein |
I’ve seen a few rear cooler installations. Mostly for bigger type IV motors. I was wondering if it was worth the effort to plumb something into the fender. I understand that the location is far from ideal. It is amazing to me that everything stays relatively cool using solely the engine oil cooler. I even double checked my gauge for accuracy. I guess until I decide to open the nose up and do it correctly, the consensus is leave it alone. One less thing on the “to do” list! I appreciate everyone’s input. I almost bought a narrow body 3.2 (seller took a higher offer after we shook hands on the deal) that ran fine without an aux cooler. We took an hour long drive in the summer and he didn’t baby it a bit. Some engines just run cool. Nothing wrong with that. There’s always money to be spent elsewhere. |
mepstein |
What is your oil compassity like 12 -15 quarts or something I imagine that has something to do with keeping the engine cool About 9 quarts. More oil may take longer to warm up but it doesn’t cool the engine any better unless the heat is transferred out of the oil with a cooler. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
When in doubt shoot the oil tank with a non contact IR thermometer, your true oil temp will let you know if you really need more oil cooling.
Here's another approach: http://www.914world.com/bbs2/index.php?sho...p;hl=oil+cooler |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,263 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
I researched every thread I could find. There are three rear mounted options each with its pros and cons
1) horizontal under the trunk floor - fairly easy to do with minimal car cutting. Works with a good fan. 2) in the right rear fender ala Perry - no personal experience but I really think this is a great way to do it - min car cutting, clean and effective. 3) under the rear engine cover - really like this setup as it requires no fan and no car cutting. Some think there is a net zero improvement in cooling efficiency. I don’t agree. And it is endorsed by Henry Schmidt :-) I chose 1) with a fan and an elaborate duct/plenum that worked very well and I figured a way to do it with zero car cutting. (Here is a thread http://www.914world.com/bbs2/index.php?sho...=314444&hl= ). I did not include a pressure relief/thermostat and blew the cooler on a very cold day due to overpressuring the cooler on start up. I abandoned the whole thing and returned to stock. No cooler Works fine for street driving. 2.4S motor. All three take about the same dollars and work. Doing it over I would probably do 3). Probably simplest, cheapest as it requires no fan or thermostatic switch, and fits well. Takes some thought and engineering to do iany of the three right to includie cold start pressure relief. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:55 AM |
